DHCP Ques
aamercado
Level 4
Level 4
Router @ Remote site (flash:c2800nm-spservicesk9-mz.123-8.T8.bin") and MS-DHCP server at central site
currently helper address at remote points back to central to pull address
But I want remote router to act as dhcp server for voip phones and have
helper-address only on data vlan back to central below is snapshot of current
configs
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.11
description Corporate Systems
encapsulation dot1Q 11
ip address 10.5.11.1 255.255.254.0
ip helper-address 10.1.2.30
service-policy output BRANCH-LAN-EDGE-OUT
interface GigabitEthernet0/0.131
description $FW_INSIDE$
encapsulation dot1Q 131
ip address 10.5.131.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
Only 11 and 131 has helper-address. I want to keep helper on 11 but take out
helper on 131 and make router a dhcp server. Can I do this or will the router
process dhcp differently? How does the router process dhcp process in this
scenario?
It should just work fine. While VLAN 131 would get an IP from the router, acting as the DHCP server, the router would forward DHCP request to the helper address configured for vlan 11. IP helper-address applied on the interface should take precedence over the configured DHCP scope in the router itself.
Sundar
