07-26-2018 10:44 AM - edited 03-05-2019 10:48 AM
I am using a 3650 as a dhcp server for several vlans and any client that attempts to get a dhcp address receives a nak from the 3650. I have a base configuration attached, as well as a png of the wireshark capture showing base info seen. Is there some default configuration on this hardware that disable the dhcp functionality, I am using IOS 16.8.1a, and had the same result with 16.6.4. The same dhcp configuration seems to work fine on a 3850. Or is there some needed configuration that I am missing?!
Scott.
Solved! Go to Solution.
07-26-2018 11:14 AM
Take another look at the mask on the Vlan101 interface:
interface Vlan101
ip address 172.16.0.5 255.255.255.248
no ip route-cache
should be 255.255.248.0.
Also, i just noticed this, take a second look at the excluded addresses for:
ip dhcp excluded-address 192.168.5.1 192.168.51.10
ip dhcp excluded-address 192.168.5.250 192.168.51.254
07-26-2018 12:24 PM
Thank you much, that was exactly IT! Since none of the dhcp scopes worked, I was only troubleshooting the 172.16.0.0/21 one, but the exclude on 192.168.5... disabled everything on the other 2 scopes. Always good to get a second set of eyes - very much appreciated!!
-Scott.
07-26-2018 11:12 AM
the default router IP addresses configured in the DHCP pools and the addresses configured on the actual VLAN interfaces do not match. Also, Vlan 101 has a wrong subnet mask configured:
ip dhcp pool dl-101
network 172.16.0.0 255.255.248.0
default-router 172.16.0.1
dns-server 8.8.8.8
lease 0 2
ip dhcp pool emn-301
network 192.168.31.0 255.255.255.0
default-router 192.168.31.1
dns-server 8.8.8.8
ip dhcp pool clr-501
network 192.168.51.0 255.255.255.0
default-router 192.168.51.1
dns-server 8.8.8.8
lease 0 2
interface Vlan101
no ip route-cache
interface Vlan301
ip address 192.168.31.5 255.255.255.0
no ip route-cache
interface Vlan501
ip address 192.168.51.5 255.255.255.0
no ip route-cache
Change it to:
interface Vlan101
ip address 172.16.0.1 255.255.248.0
no ip route-cache
interface Vlan301
ip address 192.168.31.1 255.255.255.0
no ip route-cache
interface Vlan501
ip address 192.168.51.1 255.255.255.0
no ip route-cache
07-26-2018 11:14 AM
interface Vlan101
no ip route-cache
07-26-2018 12:24 PM
-Scott.
07-26-2018 12:26 PM - edited 07-26-2018 12:26 PM
