DHCP snooping
adamgibs7
Level 6
Level 6
Hello
i want to implement DHCP snooping and below are the commands, can any body confirm that i am on the correct path of configuration, or else anybody can route me to the configuration example.
too enable globally
Switch(config)# ip dhcp snooping
to enable on specific user vlans
Switch(config)# ip dhcp snooping vlan 10 100
DHCP server interface on the switch
Switch(config-if)# ip dhcp snooping trust
To detect a fake DHCP in vlan 10,100
Switch(config)# ip dhcp snooping detect spurious vlan 10,100
Time interval for detecting suprios DHCP server
Switch(config)# ip dhcp snooping detect spurious interval 50
Hello
1) requires to active ip dhcp snooping the ip dhscp snooping vlan xx - Completed
2) if applied to one switch with uplinks switches, then the uplink switch will require snooping enabled also and its trunk links trusted  ONLY if the dhcp server is originating from the uplink switch.- Completed
3) if dhcp server is attached to the same switch as the snooping database then just trust
 the interface where the server is situated - Completed
FYI - As long as interfaces are trusted the snooping database does nothing else.
It listens on the the untrsuted ports and snoops the ip & macs.
Snooping database WILL NOT be populated with exisitng clients,
it will populate next time dhcp renews
res
Paul
Kind Regards
Paul
Dear Paul
Do i require a below command and what exactly it does, i have read but not pretty sure.
Switch(config)# ip dhcp snooping information option
thanks
