DHCP table
paulineagawin
Visitor
Hi! Im having a bit of trouble with packet tracer. im not sure if i made it right because 2 PCs cant renew their ipadd,subnet mask and default gateway but the other one is correct. here is the table that i made
r1------g0/0-----192.168.1.254-----255.255.255.0              int g0/0
   ------g0/1-----192.168.2.254-----255.255.255.0              ip helper-address 192.168.3.2
   ------s0/0/0----192.168.3.1-------255.255.255.0             int g0/1
r2------s0/0/0----192.168.3.2-------255.255.255.0             ip dhcp excluded-address 192.168.1.254
   ------s0/0/1-----209.165.200.225---255.255.255.252       ip dhcp excluded-address 192.168.2.254
        ip dhcp excluded-address 10.1.1..2
        ip dhcp pool PC1
        network 192.168.1.0 255.255.255.0
        default-router 192.168.1.254
        ip dhcp pool PC2
        network 192.168.2.0 255.255.255.0
        default-router 192.168.2.254
        ip dhcp pool PC3
        network 10.1.1.0  255.255.255.252
        default-router 10.1.1.2
r3------s0/0/1-----209.165.200.226----255.255.255.252
   ------g0/0-------10.1.1.2-----------255.255.255.252
13 Replies 13
We will need more information. Please share your network diagram; we need to know which device is plugged in where and which ones are not getting IP addresses.
HTH,
Meheretab
paulineagawin
Visitor
Please share your config as well.
HTH,
Meheretab
Router0#conf t
Router0(config)#int g0/0
Router0(config-if)#ip helper-address 192.168.3.2
Router0(config-if)ex
Router0(config)#int g0/1
Router1#conf t
Router1(config)#int g0/0
Router1(config-if)#ip helper-address 209.165.200.225
Router2#conf t
Router2(config)#ip dhcp excluded-address 10.1.1.2
Router2(config)#ip dhcp excluded-address 192.168.1.254
Router2(config)#ip dhcp excluded-address 192.168.2.254
Router2(config)#ip dhcp pool SERVER
Router2(dhcp-config)#network 10.1.1.0 255.255.255.252
Router2(dhcp-config)#default-router 10.1.1.2
Router2(config)#ip dhcp pool PC1
Router2(dhcp-config)#network 192.168.1.0 255.255.255.0
Router2(dhcp-config)#default-router 192.168.1.254
Router2(config)#ip dhcp pool PC2
Router2(dhcp-config)#network 192.168.2.0 255.255.255.0
Router2(dhcp-config)#default-router 192.168.2.254
dhcp works in router1 > PC2
Thank you for posting the network diagram and part of the config. It seems like some commands are missing. Please share the output of sh run on all three routers. Also, sh ip int bri | ex unassigned
HTH,
Meheretab
router 0
Router#sh ip int bri | ex unassigned
GigabitEthernet0/0 192.168.1.254 YES manual up up
GigabitEthernet0/1 192.168.2.254 YES manual up up
Serial0/0/0 192.168.3.1 YES manual up up
hostname Router0
interface GigabitEthernet0/0
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.2.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.3.1 255.255.255.0
router rip
network 192.168.1.0
network 192.168.2.0
ip classless
end
router 2
Serial0/0/0 192.168.3.2 YES manual up up
Serial0/0/1 209.165.200.225 YES manual up up
hostname Router2
ip dhcp pool SERVER
ip dhcp pool PC1
ip dhcp pool PC2
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 192.168.3.2 255.255.255.0
clock rate 2000000
interface Serial0/0/1
ip address 209.165.200.225 255.255.255.252
interface Vlan1
no ip address
shutdown
router rip
version 2
network 192.168.0.0
default-information originate
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/1
end
router 1
Router# sh ip int bri | ex unassigned
GigabitEthernet0/0 10.1.1.2 YES manual up up
Serial0/0/1 209.165.200.226 YES manual up up
hostname Router1
ip address 10.1.1.2 255.255.255.252
duplex auto
speed auto
ip address 209.165.200.226 255.255.255.252
clock rate 2000000
ip classless
ip route 192.168.0.0 255.255.252.0 Serial0/0/1
e con 0
line aux 0
line vty 0 4
login
end
Pauline,
PC2 was getting IP address because there is a default route on Router2 ( ip route 0.0.0.0 0.0.0.0 s0/0/1) pointing back to Router1; however, there is no route to the other networks connected to Router0. I saw that there is a  routing issue.
You run RIP on Router0 and Router2. You will need to modify the advertised networks a little bit as follows:
On Router0:
router rip
 network 192.168.3.0
On Router2:
router rip
 network 192.168.3.0
HTH,
Meheretab
HTH,
Meheretab
Hi @paulineagawin,
Also, in router 0 you must add the commands in the RIP configuration:
version 2
no auto-summary
it worked! thank you!!!
oh my god!
it works!!!
thank you thank you so much! whats left is ACL but I can handle it
again thank you thank you so much!
Hi  @paulineagawin,
You're welcome, we're here to help you.
