How can I choose best router series for load balancing?
nurlazz
I will make an essay for my study. There is about load balancing, can anyone give me suggestion which router is the best for that? Thanks
Seb Rupik
Hi there,
With regard to load balancing are you talking about IP, application or route load balancing?
If it is the latter any, cheap ISR  (1841, 880 series) will be capable of protocol-independent and protocol based route load-balancing.
You may be better off just using an emulator like GNS3, EVE-NG or VIRL instead of purchasing hardware.
cheers,
Seb.
