Can not Ping GRE destination after set up MPLS VPN
Maivoko
I am doing a lab for MPLS VPN + IPSec GRE
can not Ping after setup GRE and MPLS VPN
only can Ping using MPLS VPN IPSec VTI which no GRE
do I need to configure MTU to make GRE pingable? What MTU value should be configured ?
the recommended values are:
interface Tunnel1
ip mtu 1400
ip tcp adjust-mss 1360
That said, I am not sure that this is causing the reachability problem. Can you post the configs of both sides ?
I think alittle more info is needed and a clearer topology ....
The thing with GRE tunnels is to check that the tunnels are actually up, i always like to configure a keep-alive to get around this.
I succeed to do the lab
it do not need to change MTU
i discover that I just type wrong tunnel destination ip address
