DHCP to router interface
Nader ibrahimi
Hello to everyone
I used the dynamic means dhcp method in order to assign ip address to the router interface whenever i used the show ip route command i encounter to a new option as above picture [254/0]
My question is what is exactly the 254 means ?although i know the 0 means AD.
Require details information
Hello
Thas the administrative distance (254) applied to a received default route from dhcp, hence usually its recommended to override that dynamic default route allocation with a static default route which will have an administrative distance of 1 by default
example:
ip route 0.0.0.0 0.0.0.0 eth0/1 10.1.1.1
Kind Regards
Paul
Hello
example:
Kind Regards
Paul
Blue_Bird
Hello @Nader ibrahimi
In a Cisco routing table, "[254/0]" represents a static route with an administrative distance of 254. This means the route is manually configured and has a lower priority than routes learned via dynamic routing protocols (which typically they have administrative distances less than 254)
Best regards
******* If This Helps, Please Rate *******
