11-11-2017 02:47 AM - edited 03-05-2019 09:28 AM
I configured the interface as follow
interface FastEthernet0/3
switchport access vlan 201
switchport mode access
switchport voice vlan 200
spanning-tree portfast
The IP telephony take IP from VLAN 201 not from vlan 200.
I attached a wireshark log , please check row 388 , 398
11-11-2017 03:59 AM
post the full configuration, you might be missing something...
11-11-2017 04:25 AM
Procurve 3500YL
Running configuration:
; J8692A Configuration Editor; Created on release #K.15.16.0014m
; Ver #0b:34.00.00.00.00.74.fc.7f.ff.3f.ef:e7
hostname "HP-Core1"
module 1 type j86xxa
ip routing
snmp-server community "public" unrestricted
vlan 1
name "DEFAULT_VLAN"
no untagged 13-20
untagged 1-12,21-24
ip address 192.168.15.209 255.255.255.0
dhcp-server
exit
vlan 200
name "voice"
tagged 13-20
ip address 192.168.200.1 255.255.255.0
ip helper-address 192.168.15.209
qos priority 5
voice
exit
vlan 201
name "hr"
tagged 13-20
ip address 192.168.201.1 255.255.255.0
exit
vlan 202
name "purchase"
tagged 13-20
ip address 192.168.202.1 255.255.255.0
exit
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
dhcp-server pool "hr"
default-router "192.168.201.1"
dns-server "192.168.15.53,192.168.15.55"
network 192.168.201.0 255.255.255.0
option 132 ascii "p51=200"
range 192.168.201.50 192.168.201.250
exit
dhcp-server pool "voice"
default-router "192.168.200.1"
network 192.168.200.0 255.255.255.0
range 192.168.200.50 192.168.200.250
exit
dhcp-server pool "purchase"
default-router "192.168.202.1"
network 192.168.202.0 255.255.255.0
range 192.168.202.50 192.168.202.250
exit
11-11-2017 04:36 AM
first of all, how is the trunk link between the Cisco and the HP configured ? Do all VLANs exists on the Cisco (show vlan) ?
What is the purpose of the 'ip helper-address 192.168.15.209' ? Typically you wouldn't need those commands if the DHCP pool is locally configured on the switch...
11-11-2017 04:39 AM
cisco switch :
interface FastEthernet0/1
switchport trunk allowed vlan 200-210
switchport mode trunk
interface FastEthernet0/2
11-11-2017 04:40 AM
Switch#show vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/5, Fa0/6
Fa0/7, Fa0/8, Fa0/9, Fa0/10
Fa0/11, Fa0/12, Fa0/13, Fa0/14
Fa0/15, Fa0/16, Fa0/17, Fa0/18
Fa0/19, Fa0/20, Fa0/21, Fa0/22
Fa0/23, Fa0/24, Gi0/1, Gi0/2
200 voice active Fa0/3, Fa0/4
201 hr active Fa0/3
202 purchase active Fa0/4
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
11-11-2017 04:41 AM
HP-Core1# show vlans
Status and Counters - VLAN Information
Maximum VLANs to support : 256
Primary VLAN : DEFAULT_VLAN
Management VLAN :
VLAN ID Name | Status Voice Jumbo
1 DEFAULT_VLAN | Port-based No No
200 voice | Port-based Yes No
201 hr | Port-based No No
202 purchase | Port-based No No
11-11-2017 04:48 AM
typically you would need option 150 in the voice DHCP pool, pointing to the TFTP server on the same VLAN. Not sure how to configure this on the HP...
On the Cisco it would be:
option 150 ip x.x.x.x
11-11-2017 04:53 AM
if I need to put the VLANID in DHCP option for IP telephony , what I need to do
11-11-2017 05:02 AM
Actually, option 150 is Cisco proprietary, the HP equivalent would be option 66.
You need a TFTP server containing the .cnf files.
That said, what if you remove the helper address ?
11-11-2017 03:29 PM
You are attempting to configure a voice vlan on a Cisco switch that connects to a Grandstream IP Phone. However your switch is not sending out any LLDP messages and oddly enough neither is your IP Phone. The VLAN ID for voice is included in the CDP message for example Line 123 of you pacp... if you expand Cisco Discovery Protocol and expand VoIP VLAN REPLY.. you will see the Voice VLAN ID 200.. however, the Grandstream phone does not support CDP hence ignores this info... so enable LLDP on your switch. This way LLDP messages are shared between the switch and the phone. You will see in the LLDP-MED message a field for the network policy and the vlan ID. You might need to check if the Grandstreams support Voice VLAN's and LLDP MED as they are not sending any LLDP's as well which is quite odd..
11-12-2017 12:37 PM
Hello
You show a cisco port /trunk configuration and then a Hp switch configuration, You also have dhcp server enabled on the hp switch with various scopes including vlan 200 but you are also specifying dhcp relay ( this inst required)
Assuming that you have a Cisco-hp switch connected to each other and the ip phone connected to a cisco access port
Can you confirm the following:
Your voice l3 vlan on the hp is set to voice with qos priority ( is this required?)
Have you tried enabling LLDP instead of CDP for link discovery?
Do you have any dhcp snooping enabled for vlan 200?
Do you have QOS enabled on the cisco switch?
Do you obtain dhcp for vlan 200 it you just attached a normal host to the port and assigned it to vlan 200 ( not as a voice vlan)
res
Paul
11-12-2017 09:37 PM
- I got from Internet , I think it is not required
- I don't known how to enable it
