dhcp
Network_kenn
I have a cisco router setup as a DHCP server and a cisco switch for clients. The DNS is provided by windows server. I am having an issue where clients are receiving an IP address successfully but after the lease expires a new IP address is not issued automatically. For a client to get a new IP address I would have to disable then reenable the network adapter on the desktop of the client. How can I possibly resolve this issue
I agree that the suggested changes are good suggestions. I do not understand what the issue really is about DHCP but perhaps removing the second (incomplete) DHCP pool will help that. The other suggested changes of removing the unnecessary static route for a connected subnet, adding a default route, and changing the acl from
permit any to permit
the local subnet do improve the config but I do not see any connection to issues about DHCP.
Rick
13 Replies 13
emurray
Can you post the configuration of the router and the switch? Also, if you have the topology please post it.
Current configuration : 1507 bytes
! No configuration change since last restart
version 15.1
hostname EDULA_R1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool Enterprise
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 192.168.1.16
ip dhcp pool EDULA CLIENTS
 dns-server 192.168.1.3
license udi pid CISCO1921/K9 sn FGL170424DE
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0
access-list 1 permit any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
<<- why there is two DHCP Pool with same default router ???
that wrong
you need to delete one pool
a few things do not look right in your configuration. Make the changes/additions marked in bold. Make sure everything looks exactly like below, line by line. When you are finished, post the configuration again.
version 15.1
hostname EDULA_R1
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
 no ip address
 shutdown
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 ip nat inside
 duplex auto
 speed auto
no ip http server
--> no ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
--> access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login
 transport input all
end
okay here is the switch configs as well
Switch#sh run
Building configuration...
Current configuration : 2156 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750-48p
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface FastEthernet1/0/25
interface FastEthernet1/0/26
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
interface FastEthernet1/0/30
interface FastEthernet1/0/31
interface FastEthernet1/0/32
interface FastEthernet1/0/33
interface FastEthernet1/0/34
interface FastEthernet1/0/35
interface FastEthernet1/0/36
interface FastEthernet1/0/37
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Rick
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
friend, If the router use load balance between two pool or whatever it behave and lead to use second Pool that dont have IP this can lead what you see.
remove the second pool that use same default-router and dont have IP to assign to client.
Switch#sh run
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Vlan1
no ip address
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
what is this config ? I dont get it ?
I think you apply ACL in SW ? can I see it ?
Hello
append the following and test the dhcp renewal again:
conf t
no ip source-route
no ip dhcp pool EDULA CLIENTS
no access-list 1
Kind Regards
Paul
please to help other,
what is exact solution and if you can share last config.
thanks a lot
