Diagnosing a 400Mbps cap on Network Speed With Cisco and Watchguard Devices
Ian Stephens
We are noticing that we max our WAN port out at 400 Mbps. We have a 1Gbps connection with our provider delivered over pure Ethernet (in a datacenter).
Here is an example of the max-out using crude MRTG:
MRTG Max
We are directly connecting to our provider via Ethernet at 1Gbps. This comes in to our Cisco 2901 router and then we are then connecting directly to our Watchguard Firebox at 1Gbps Ethernet (in drop-in mode). All devices are reporting 1Gbps line speed with full duplex.
The Firebox then connects to our switch at 1Gbps. We are running a gigabit switch which connects directly to our servers (also at 1Gbps to each server).
We can't seem to achieve anything over 400Mbps through the setup. The Firebox X1250e we are running is rated at 1.5Gbps throughput for raw packet forwarding (which we are doing - no proxying or fixup is being performed on the data).
We have even fired up a command line Speedtest (Ookla) on one of the servers and it hits the 400Mbps cap.
I know people are going to say the Cisco 2901 is the issue but we are running full 1500 packets and even at 400Mbps over an extended period, this is an example of our CPU usage:
sh proc cpu
CPU utilization for five seconds: 18%/17%; one minute: 17%; five minutes: 17%
Also worth noting, we are not running any QoS on the Firebox - all QoS is disabled (the whole module unloaded).
The Cisco 2901 has CEF enabled.
We have the following configuration:
Network Diagram
Does anybody know what may be causing this "cap"?
Also, we have been monitoring the interfaces:
5 minute output rate 399034000 bits/sec, 33444 packets/sec
This shows ~33,000 pps (33 kpps).  We already know the Cisco 2901 can handle 330 kpps @ 64 bytes.
We would like some tips, advice and suggestions as to how we can diagnose this remotely (we can't easily go to the datacenter to perform tests).
Any help and advice are greatly appreciated; thank you in advance.
11 Replies 11
Ian Stephens
Also, just following on...
If the router is to blame, how can we confirm that the router is at max capacity?  The CPU figures and PPS data don't seem to show max load.
Thank you for your help.
are we talking about a layer 2 or a layer 3 GigabitEthernet link on the 2901 ? Can you post the output of 'show interfaces GigabitEthernetx' from the router interfaces connected to the ISP and the WatchGuard ?
Thank you for your reply.  Here are the outputs for both interfaces.
Connection to Watchguard Firebox
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is x.x.x (bia x.x.x)
  Description: connected to Watchguard
  Internet address is x.x.x.x/26
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 80/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:18, output 00:00:00, output hang never
  Last clearing of "show interface" counters 15:45:22
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 448
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 317600000 bits/sec, 26722 packets/sec
  5 minute output rate 4504000 bits/sec, 9569 packets/sec
     1342335516 packets input, 1360008449 bytes, 448 no buffer
     Received 223 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 8662 pause input
     510961103 packets output, 325652526 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Connection to ISP
GigabitEthernet0/1 is up, line protocol is up
  Description: connected to ISP
  Internet address is x.x.x.x/30
     reliability 255/255, txload 80/255, rxload 1/255
  output flow-control is unsupported, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 4902000 bits/sec, 9569 packets/sec
  5 minute output rate 317599000 bits/sec, 26723 packets/sec
     510902327 packets input, 2594822340 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1342353598 packets output, 1354131150 bytes, 0 underruns
layer 3 throughput for the 2901 is indeed rated at about 3Gig (I assume you have seen the same data as in the attached white paper).
This might sound too obvious, but I would check with the ISP if they actually provide the full 1G. If they say they do, and if you can afford the downtime, I would take out the Cisco and the WatchGuard to see if eliminating any of these two devices from the topology increases the speed...
Interfaces look clean by the way, no drops. I assume you have CEF enabled ? If possible, post the config of the 2901, we might be able to spot something...
https://community.cisco.com/t5/switching/throughput-of-2901-router/td-p/2174748?attachment-id=51462
Hi Georg,
Thank you for your response (and for also confirming we should be able to achieve greater throughput than 400Mbps with a 2901 @ 1500 bytes).  This was the main reason for opening this thread - to get confirmation that the router wasn't maxed out.
I will open a support ticket with our provider now and confirm everything is correct on their end (no rate limiting or policing policies).
I can indeed disconnect everything for 5 minutes and plug a machine directly into the Ethernet cable provided by our ISP.  I will wait until after the holidays and probably do it at a quiet period (2-3am).  I will also wait to see what our provider says before I arrange this too.  I will set up the network configuration on a laptop before I head up the datacenter so I can quickly unplug/test/reconnect everything.
Yes, interfaces look good.
Yes, CEF is enabled.
We are running a very simple config.
Here is our simplified conf (only the important parts with certain elements removed with "x".)
hostname x.x.x.net
logging buffered 51200 warnings
no aaa new-model
ethernet lmi ce
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
redundancy
buffers tune automatic
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description connected to xxx
ip address 195.xxx.xxx.xxx 255.255.255.192
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 195.xxx.xxx.xxx 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 195.xxx.xxx.xxx
snmp-server community public RO 23
snmp-server community intsnmp RO 96
snmp-server location London, United Kingdom
snmp-server contact xxx xxxx, +44.xxxxxxxxxxx, xxx@xxx.com
access-list 23 permit 148.xxx.xxx.xxx
access-list 23 permit 195.xxx.xxx.xxx 0.0.0.63
access-list 96 permit xxx.xxx.xxx.xxx
For what it's worth:
#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.5(3)M, RELEASE SOFTWARE (fc1)
Hello
it may have nothing to do with any of your line rates but more than the bdp-rwin between your site and the end host you testing
what is the RTTyou are obtaining?
use the following calculation url to check the expected Rwin regards you BDP RTT
Bdp/rwin
Kind Regards
Paul
Thank you for your reply, Paul.
It's not a single thread or host we are testing with.
We have two servers providing downloadable files over HTTPS which can have over 50-100 active connections at the same time (the files are large).
We notice the ~400Mbps limit when these servers are busy (Sunday eve etc).
But also, even with a single thread/host test such as CLI speedtest.net we notice the exact same limit.
Many thanks.
Hello
I would definitely check if the windows scailling is set up correctly on those servers to see if your connection improves becasue if it isn’t then what you are experiencing does seem to suggest its a possibility
Kind Regards
Paul
Hi Paul,
I know our servers are auto-scaling:
admin@rackarray1:/$ sysctl net.ipv4.tcp_window_scaling
net.ipv4.tcp_window_scaling = 1
What else should I be looking at?
We have modified the window sizing settings on the servers to the following:
net.core.rmem_max = 67108864
net.core.wmem_max = 67108864
net.ipv4.tcp_rmem = 4096 87380 33554432
net.ipv4.tcp_wmem = 4096 65536 33554432
However, the ~400Mbps limit persists.
