Dialer Interface - High Total Output Drops
cheonghomtai
Can someone give me some links to Dialer Interface info?
I have some issues with my Dialer 1, having lots of Total drops.
My internet connection is broadband (10 Mbps) using fiber,
interface Dialer1
description *** DIALER-1 GROUP-11 POOL-111 ***$FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
ip virtual-reassembly max-reassemblies 512
zone-member security ZONE-3
encapsulation ppp
ip tcp adjust-mss 1460
dialer pool 111
dialer idle-timeout 0
dialer persistent
dialer-group 11
ppp authentication chap pap callin
ppp chap hostname xxxx
Here's the output:
ISR2811#sh int dialer 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: *** DIALER-1 GROUP-11 POOL-111 ***$FW_OUTSIDE$
  Internet address is 2xx.xx.xx.161/32
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 1/255, rxload 8/255
  Encapsulation PPP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi3
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2w2d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 56468
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
  5 minute input rate 58000 bits/sec, 1 packets/sec
     29068998 packets input, 1586452367 bytes
     15238816 packets output, 18446744072203736053 bytes
Bound to:
Virtual-Access3 is up, line protocol is up
  Hardware is Virtual Access interface
     reliability 255/255, txload 4/255, rxload 8/255
  Encapsulation PPP, LCP Open
  Listen: CDPCP
  Open: IPCP
  PPPoE vaccess, cloned from Dialer1
  Vaccess status 0x44, loopback not set
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:05, output never, output hang never
  Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     29228665 packets input, 1588587279 bytes, 1 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     15238850 packets output, 2789157092 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
Virtual-Access1            unassigned      YES unset  down                  dow
Virtual-Access2            unassigned      YES unset  up                    up
Virtual-Access3            unassigned      YES unset  up                    up
Dialer1                    2xx.xxx.xxx161   YES IPCP   up                    up
Question:
1 - Why is there 3 Virtual Access?
2- Virtual Access 3 is bound to dialer 1, what about VA2 and VA1?
Thanks again.
18 Replies 18
cheonghomtai
Anyone can shed some light?
TQ
Abdullah Net
Level 3
Level 3
cheonghomtai,
Can we see your full configuration and not just the parts you have shown to better locate the problem.
Abdullah,
Here's the LAN and WAN subinterface:
interface FastEthernet0/0
description OFFICE-LAN1$FW_INSIDE$
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description *** VLAN 1 ***
encapsulation dot1Q 1 native
ip address 192.168.100.254 255.255.255.0
ip nbar protocol-discovery
ip flow ingress
ip nat inside
ip virtual-reassembly max-reassemblies 128
zone-member security ZONE-1
ipv6 address XXXX
ipv6 enable
service-policy input XXX_POLICY
interface FastEthernet0/0.200
description *** VLAN 200 ***
encapsulation dot1Q 200
ip address 192.168.200.254 255.255.255.0
ip flow ingress
ip nat inside
interface FastEthernet0/1
description Going To BTU
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1.500
description ** VLAN-500 DATA **
encapsulation dot1Q 500
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pppoe enable group global
pppoe-client dial-pool-number 111
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 111
dialer persistent
dialer-group 11
paolo bevilacqua
And which router and IOS is this ?
Its a 2811 ISR router.
System image file is "flash:c2800nm-adventerprisek9-mz.124-22.T.bin"
Subeh Sharma
Level 4
Level 4
Answers inline:
Think of dialer interface as a template from which virtual-access interfaces get created "on demand" i.e. whenever there is a traffic being sent out or received.
What this means is that VA2 & VA1 like VA3 was used earlier for traffic passing. Sometimes, more than 1 virtual access interfaces are created when the traffic flow is between two different endpoints traversing the router. If you want to know whether any VA interface is being used or not, check "show interface va<>". In the output you if you see something like "PPPoE vaccess, cloned from Dialer1" then it indicates this particular VA is being used currently. If a VA is not being used anymore by the router, you will not see "PPPoE vaccess, cloned from Dialer1" there.
As for the output drops, i see that the counter was cleared more than 2 weeks ago, try clearing the counters "clear counters" and monitor this output differnt times of the day to asertain whether the output drop is incrementing all the time or only during certain hours of the day and let us know. Also past the 'show interface
Subeh
Hi Subeh,
Thanks for the comprehensive answers.
Now i know why few VA are generated based on traffic.
As for the counters, yes i have cleared 2 wks ago.
But it seems like its incrementing all the time, and i don't see any pattern at all.
The dialer 1 is bounded to the sub-int FA0/1.500
ISR2811#sh  int fa0/1.500
FastEthernet0/1.500 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0018.ba0a.6cf1 (bia 0018.ba0a.6cf1)
  Description: ** VLAN-500 DATA **
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  500.
FastEthernet0/1 is up, line protocol is up
  Description: Going To UNIFI BTU
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/43/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 12000 bits/sec, 12 packets/sec
  5 minute output rate 9000 bits/sec, 8 packets/sec
     164946397 packets input, 2889581039 bytes
     Received 31499799 broadcasts, 0 runts, 0 giants, 4 throttles
     3745 input errors, 5 CRC, 2002 frame, 0 overrun, 1738 ignored
     0 watchdog
     82235932 packets output, 2732695477 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
Thanks!
Hom
Hom,
Can you check if the rate of traffic being sent out from the dialer inteface is under the subscibed rate you got from the ISP? Becuase the 'Total Output drop' counter shows packets which are dropped either due to any/all of the following:
- The output rate being higher than the physical link subscribed rate.
- Failing hardware.
- IOS issue.
I see you've ZBF configured under dialer interface. Is it possibel for you to remove it for testing and then check if somehow the ZBF policy is interfering with the traffic?
Subeh
Hi Subeh,
Here's the latest update which I cleared this morning:
Hardware is Unknown
Description: *Dialer-1 Grp-11 Pool-111
Internet address is 219.92.xx.xx/32
    reliability 255/255, txload 227/255, rxload 1/255
Last clearing of "show interface" counters 07:39:11
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1033
    Conversations  0/0/16 (active/max active/max total)
5 minute input rate 0 bits/sec, 1 packets/sec
5 minute output rate 50000 bits/sec, 1 packets/sec
    729057 packets input, 522790776 bytes
    430683 packets output, 95170678 bytes
ISR2811#sh int virtual-access 2
Virtual-Access2 is up, line protocol is up
  MTU 1492 bytes, BW 100000 Kbit/sec, DLY 100000 usec,
  Encapsulation PPP, LCP Closed
  Base PPPoE vaccess
  DTR is pulsed for 5 seconds on reset
  Last clearing of "show interface" counters 13w5d
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
As for the BWidth - its 10Mbps line.
Is this the correct way to identify the speed of the line?
For the ZBF, i think that shouldn't be an issue coz i have another 1841 with similiar ZBF but no drops output.
I can only remove the ZBF when no users are around - during the weekend.
Here's my other Router:
System image file is "flash:c1841-adventerprisek9-mz.151-4.M.bin"
1841#sh int dialer 1
  Hardware is Unknown
  Internet address is 175.xx.xx.xx/32
     reliability 255/255, txload 255/255, rxload 255/255
  Encapsulation PPP, LCP Closed, loopback not set
  Interface is bound to Vi2
  Input queue: 0/75/16723/0 (size/max/drops/flushes); Total output drops: 25
  5 minute input rate 1699000 bits/sec, 230 packets/sec
  5 minute output rate 548000 bits/sec, 162 packets/sec
     804444333 packets input, 2600720886 bytes
     606586814 packets output, 3251055407 bytes
Bound to:
  Stopped: CDPCP
  Open: IPCP
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 09:34:17
  Input queue: 0/75/16/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 1697000 bits/sec, 231 packets/sec
  5 minute output rate 565000 bits/sec, 190 packets/sec
     10075877 packets input, 2875107193 bytes, 16 no buffer
     Received 0 broadcasts (0 IP multicasts)
     7446225 packets output, 1194558143 bytes, 0 underruns
I noticed the input queue DROP size is huge.
I hv read that its not a gd idea to tweak any of it - which can cause timout + TCP retransmit flooding in.
Any thoughts are welcome?
for your 2811, i don't think the virtual-access2 you pasted is the one which is being used becuase in show interface virtual-access 2 , i don't see the statement, " PPPoE vaccess, cloned from Dialer1" so it can't be the right one. But moving ahead, do this, under dialer interface, configure 'output hold-queue 400' and then see if it improves the situation.
You're right in saying that tweaking the hold-queue can have impact of the traffic flow but it is only if you increase it to, say, 1500 or more. You can try putting the value of the queue from 400 to 800 for checking any improvement.
Subeh
I found this document which applies to both your router's problem. Let me know if the suggestions mentioned it provides some improvements:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
Subeh
Funny, 2811 got 3 VA. 1841 has 2 instead.
Somehow the bandwidth is tied to VAx?
2811 is VA3
    reliability 255/255, txload 4/255, rxload 1/255
1841 is VA2
Ok - will try out the out hold-queue values.
TQ
VAs are created on demand and nothing to do with the bandwidth of the link. Give it some time and you'll see on 1841 more numbers of VAs, provided the ones which were created are not deleted automatically due to inactivity. Anyways, even if a VA is being shown in 'show ip int brief' and not being used, it'd not matter becuase as its a virtual interface, it wil not consume any memory or CPU cycles.
Subeh
