Dialer not coming up
DanJay3411401
Dear all,
I am in a rural area in southern Germany on a ADSL2+ Line, my C886 VA-W (K9) box trains this as follows:
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'BDCM'
Chip Vendor Specific: 0x0000 0x93EF
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FCZ185392DV C886VA-W 15.2(4)M
Serial Number Far:
Modem Version Near: 15.2(4)M
Modem Version Far: 0x93ef
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.5 (ADSL2+) Annex B
TC Mode: ATM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Trellis: ON OFF
Firmware Source File Name (version)
VDSL user config flash:VA_B_38V_d24m.bin (10)
Modem FW Version: 170321_1253-4.02L.03.B2pvC038v.d24m
Modem PHY Version: B2pvC038v.d24m
Vendor Version: Bpv38v.24m 68
Here's the relevant part of the config; as this is Annex B the fun stuff happens on the ATM side of things with e0 being shut and (because it's ADSL2+) no tagging on sub-ifs:
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
pvc 1/32
oam-pvc manage
pppoe-client dial-pool-number 1
Here's the dialer:
interface Dialer2
description DSL - Uplink
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer string "*99#"
dialer-group 1
ipv6 enable
ppp authentication pap callin
ppp pap sent-username [snip]
ppp ipcp dns accept
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
no cdp enable
crypto map generic
e0:
interface Ethernet0
no ip address
no ip route-cache
shutdown
Dial out Controls:
ip nat inside source route-map natexclude interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer2
access-list 90 permit 192.168.2.0 0.0.0.63
access-list 120 permit ip 192.168.2.0 0.0.0.255 any
access-list 197 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 198 permit ip 192.168.2.0 0.0.0.255 any
dialer-list 1 protocol ip list 120
route-map natexclude permit 10
match ip address 198
egress Traffic is being recognized as interesting as per list 120, but DSL does not come up because of Di2: No free Dialer, and I cannot the heck figure out what I did wrong in the binding. Can some kind person shed some light on this ?
Also, try and leave the configuration as it originally was and remove the dialer string from the Dialer interface:
-> no dialer string "*99#"
8 Replies 8
who exactly is your ISP ? A lot of times the ISPs require you to configure a subinterface. Try the two different ATM interface configs below:
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 1/32
oam-pvc manage
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface ATM0
no ip address
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 1/32
If that doesn't help, post the entire config...
ISP Config: Contractor is easybell, Carrier is QSC.
Georg:
No Luck, here's the config with what you suggested.
version 15.2
hostname snip
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip cef
ip dhcp excluded-address 192.168.2.13
ip dhcp excluded-address 192.168.2.7
ip dhcp excluded-address 192.168.2.6
ip dhcp excluded-address 192.168.2.4
ip dhcp excluded-address 192.168.2.5
ip dhcp excluded-address 192.168.2.24
ip dhcp excluded-address 192.168.2.8
ip dhcp excluded-address 192.168.2.11
ip dhcp excluded-address 192.168.2.9
ip dhcp pool localdhcp
network 192.168.2.0 255.255.255.192
default-router 192.168.2.1
option 66 ip 192.168.2.7
option 150 ip 192.168.2.7
dns-server 192.168.2.24
lease 30
ip dhcp pool guest_dhcp
network 192.168.2.64 255.255.255.224
dns-server 8.8.8.8
default-router 192.168.2.33
lease 30
ip domain name snip
ip name-server 8.8.8.8
ip inspect name protect_jt http
ip inspect name protect_jt dns
ipv6 unicast-routing
ipv6 cef
license udi pid C886VA-W-E-K9 sn FCZ185392DV
username snip
controller VDSL 0
firmware filename flash:VA_B_38V_d24m.bin
crypto ipsec transform-set generic_transform esp-aes
mode tunnel
crypto map generic 110 ipsec-isakmp
! Incomplete
description snip
set transform-set generic_transform
set pfs group2
match address 197
reverse-route
bridge irb
interface ATM0
no ip address
pvc 1/32
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
no ip route-cache
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
switchport access vlan 2
switchport mode trunk
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
ip address 192.168.5.1 255.255.255.0 secondary
ip address 192.168.2.1 255.255.255.192
ip nat inside
ipv6 enable
interface Vlan2
no ip address
ip nat inside
ipv6 enable
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ipv6 enable
ppp pap snip
ppp ipcp dns accept
no cdp enable
crypto map generic
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
access-class 90 in
exec-timeout 0 0
timeout login response 300
privilege level 15
login local
transport input all
scheduler allocate 20000 1000
ntp server ptbtime2.ptb.de
ntp server ptbtime1.ptb.de
end
I'll check the config and get back with you...
Thanks Georg, I will now leave office and try to find a slot for testing later whatever you may find.
I have made some changes and additions to your configuration (marked in bold). The Cisco routers are not specifically mentioned on the Easybell support page, so I am not sure if they are supported at all.
You don't need a default route when you have 'ppp ipcp route default' confgured, so I removed the default route.
I have configured aal5snap for the Dialer, give that a try.
Also, some of the DHCP addresses needed to be excluded. Also, the NAT access list needed to exclude the NAT for communication between the local networks.
You also might remove the ATM subinterface and try the same configuration on the main interface.
version 15.2
hostname snip
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.2.33
lease 30
dns-server 8.8.8.8
lease 30
ip domain name snip
ipv6 cef
username snip
controller VDSL 0
mode tunnel
! Incomplete
description snip
set pfs group2
match address 197
reverse-route
bridge irb
interface ATM0
no ip address
pvc 1/32
encapsulation aal5snap ppp dialer
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
no ip route-cache
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
interface wlan-ap0
ip unnumbered Vlan1
interface Vlan1
ip nat inside
ipv6 enable
interface Vlan2
no ip address
ip nat inside
ipv6 enable
interface Dialer2
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ipv6 enable
ppp pap snip
ppp ipcp dns accept
no cdp enable
crypto map generic
no ip http server
access-list 120 permit ip 192.168.2.0 0.0.0.63 any
access-list 197 permit ip 192.168.2.0 0.0.0.63 192.168.1.0 0.0.0.255
access-list 198 deny ip 192.168.2.0 0.0.0.63 192.168.1.0 0.0.0.255
access-list 198 permit ip 192.168.2.0 0.0.0.63 any
match interface Dialer2
control-plane
line con 0
login local
no modem enable
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 90 in
exec-timeout 0 0
privilege level 15
login local
transport input all
end
Hello Georg,
I agree that the dialer string command shouldn't be needed in this context.
Best Regards
Giuseppe
Houston, we have Signal !
As soon as I altered the encaps, ppp came up nicely and leaves me with a mediocre 12 down/ 1.something up.
Thanks everyone for your kind and helpful support. I am not too frequently here (I wish I was), but please have my kudos for helping a small company with a few people do its work.
Dan
