Dialer pools - Checking which interface is being used
voiper_99
Hi, how do you find out which interface is being used when you are using dialer group with multiple interfaces in the group?
Is there some sort of show command that tells you? I have tried "show int dialer 1" but it only tells me the virtual interface which the dialer is bound to and not the physical interface that is being used to make the connection.
Any information would be greatly appreciated. Thank you.
bjornarsb
Level 4
Level 4
If I remember correct use this command:
sh ppp multilink.
Bjornasrb
Hi, sorry this does not show the information that I am after but thank you for the suggestion though.
can you try show isdn active and check ?
regds
This may work when ISDN interfaces are part of the pool but what happens if an ATM, ethernet or serial interface is being used? Thank you for your suggestion.
