Dialup Router not accepting Incoming Calls
hirmoge123_2
I have cisco 3620 router which i want to use as a dialup router. after configuring it, the PRI link from telco is up but the problem i faced is that when i dial the PRI number which is 308888 i am getting busy tone. it seams the modem refuses the call. from the trace i took i am getting this cause ( Cause i = 0x80AC - Requested circuit/channel not available).
attachment is the result of the following commands:
sh ver
sh interface Serial1/0:15
sh controller E1 1/0
debug isdn q931
sh isdn service
sh isdn status
any help about this problem is highly appreciated.
Hassan
Also configure
line 1 30
modem In
7 Replies 7
paolo bevilacqua
Can you send "show diag" and "show run" ?
I have attached
sh diag
sh run
Can you take some "show modem log" and "debug modem csm".
I have attached both command results
sh modem log
debug modem csm
Thanks for your assistant
Router can't find a free modem:
2d22h: CSM incall failed with dchan index=1, idb state=4, sb=0
2d22h: CSM: MODEM_REPORT rcvd DEV_INCALL for call_id 0x83, No modem available
Try upgrading IOS to latest available.
thanks for your prompt and kind assistance
can you please advice me which version to upgrade.
12.3(26)
Also configure
line 1 30
modem In
