Diferents fot NM-4A/S ans NM-4T ?
castro-g
Ademas of the coneccions sincronas and asincronas, that another difference has between these modulos?
NM-4A/S ans NM-4T
spremkumar
Level 9
Level 9
hi
If i have understood your query the only other general difference is the maximum bandwidth the modules can support.
NM-4 A/S supports async connectivity with speeds up to 115.2 kbps, and sync connectivity with speeds up to 128 kbps.
NM-4T supports 2 Mbps on all four ports .
regds
