Differece between Input/output & Preferred- TELNET
Rupesh Kashyap
Hi, what is the difference between Input/output and Preferred tab in Line VTY 0 4
input->>Define which protocols to use when connecting to the terminal server
output->> Define which protocols to use for outgoing connections
preferred->> Specify the preferred protocol to use
ldardon
Transmission Control Protocol/Internet Protocol (TCP/IP) is the most widely implemented protocol suite on networks of all media types. TCP/IP is today's standard for internetworking and is supported by most computer vendors, including all UNIX-based workstation manufacturers. TCP/IP includes Telnet and rlogin. Terminal services provide terminal-to-host connectivity with virtual terminal protocols, including Telnet, LAT, TN3270, and rlogin. Modems can be set up for rotary connections.
http://www.cisco.com/en/US/docs/ios/11_0/access/connection/guide/xovervw.html
