ISDN Layer 3 Problem
saravanababu22
enabled debug isdn Q931 and Q921,
recieving the below logs,
Layer 1, 2 are active, layer is also fine, still not sure, as tested by telco, voice and data calls are happening in this line,
Error message
Router#isdn test call interface s2/0:15 4019225
000435: May 4 15:18:13.736 GMT: ISDN Se2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 4019225
000436: May 4 15:18:13.736 GMT: ISDN Se2/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=75 nr=35
000437: May 4 15:18:13.736 GMT: ISDN Se2/0:15 Q931: SETUP pd = 8 callref = 0x00A6
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Called Party Number i = 0x81, '4019225'
Plan:ISDN, Type:Unknown
000438: May 4 15:18:13.744 GMT: ISDN Se2/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=76
000439: May 4 15:18:13.812 GMT: ISDN Se2/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=35 nr=76
000440: May 4 15:18:13.812 GMT: ISDN Se2/0:15 Q931: SETUP_ACK pd = 8 callref = 0x80A6
000441: May 4 15:18:13.812 GMT: ISDN Se2/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=36
000442: May 4 15:18:13.939 GMT: ISDN Se2/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=36 nr=76
000443: May 4 15:18:13.939 GMT: ISDN Se2/0:15 Q931: CALL_PROC pd = 8 callref = 0x80A6
000444: May 4 15:18:13.939 GMT: ISDN Se2/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=37
000445: May 4 15:18:14.619 GMT: ISDN Se2/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=37 nr=76
000446: May 4 15:18:14.619 GMT: ISDN Se2/0:15 Q931: DISCONNECT pd = 8 callref = 0x80A6
Cause i = 0x85D8 - Incompatible destination
000447: May 4 15:18:14.619 GMT: ISDN Se2/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=38
000448: May 4 15:18:14.651 GMT: ISDN Se2/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=76 nr=38
000449: May 4 15:18:14.651 GMT: ISDN Se2/0:15 Q931: RELEASE pd = 8 callref = 0x00A6
000450: May 4 15:18:14.659 GMT: ISDN Se2/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=77
000451: May 4 15:18:14.703 GMT: ISDN Se2/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=38 nr=77
000452: May 4 15:18:14.703 GMT: ISDN Se2/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x80A6
000453: May 4 15:18:14.703 GMT: ISDN Se2/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=39
Router#
Calls are not getting placed.
Suggestions pls.
Adrian Saavedra
Level 7
Level 7
What happens if you configure bearer-cap speech under voice-port?
Let us know how it goes.
Best regards.
