Difference between Datagram Size on "Cisco Extended Ping" & "Windows Ping"
pingwarrior
Hi all,
I have some confusion after doing some tests on my own. I was actually doing some testing to find the optimum MTU Path for my network with DF bit set and by specifying length. I did on Cisco Router as well as on Windows PC CMD Ping command. For your information, the Cisco Router and Windows PC were tested with same LAN port and both with default MTU size at the interfaces.
By using Cisco Exteneded Ping, the maximum packet size I can insert is 1492 with DF bit set while the maximum packet size for Windiows PC with DF set is 1472.
In this scenario, can I assume that Size in Cisco Extended Ping is included IP Header but Size in Windows Ping Command is not included IP Header? Correct me if I am wrong.
milan.kulik
Level 10
Level 10
Yes,
my experience is 1500 Bytes in Cisco CLI correspondes to 1472 Bytes in Windows cmd.
Your 1492 might be caused by ADSL or IPSec involved?
BR,
Milan
milan.kulik
Level 10
Level 10
Yes,
BR,
Milan
Hi Milan,
Yes. I am behind ADSL which is using PPPOE and thus getting 1492. Thanks for sharing your experience and for your confirmation.
