Difference between Default-originate and network 0.0.0.0 in BGP
turbo_engine26
Level 4
Level 4
Please i need someone to clarify what is the difference between the
"default-originate" command and "network 0.0.0.0 - ip route 0.0.0.0 0.0.0.0 null0" commands.
I see both are serving the same purpose by advertising a default route to a peer but in the same time i feel a difference on them.
Thx
A.M.
22 Replies 22
Peter, can you explain a scenario where you would use a
route map with the neighbor X.X.X.X default-originate?
take the example below.
The default route to neighbor 10.10.10.2 is injected only if there is a route to 192.168.1.0.
access-list 1 permit 192.168.1.0
route-map DEFAULT 10 permit
match ip address 1
router bgp 1
network 10.0.0.0 mask 255.0.0.0
neighbor 10.10.10.2 remote-as 2
neighbor 10.10.10.2 default-originate route-map DEFAULT
Hello @Peter Paluch ,
You said:
  • default-information originate
    causes the default route to be artificially generated and injected into the BGP RIB, regardlessly of whether it is present in the routing table.
But I believe this is not true - default-information originate requires the default route to be redistributed? It will not artificially generate the default route I believe?
Thanks!
Make new post it better
And ask your Q
This make many answer you and you can more clarify the best answer for you
MHM
Hi @ChrisNewnham_ ,
These are two different commands that are often mistaken.
router bgp xxx
address-family ipv4 unicast
neighbor x.x.x.x default-originate
router bgp xxx
When you use the "neighbor x.x.x.x default-originate", it will as mentioned in this post advertise a default route to the neighbor, regardless if the default route is present in the routing table or not.
The other command "default-information originate" configured lets say under "address-family ipv4 unicast". In this case, this will allow redistribution of the default route from any protocol into BGP. Without this command the default route would not be redistributed into BGP. The default route would definitely need to be present in the routing table in order to be redistributed into BGP.
Thanks for the information, but i still have a little doubt, what is the difference between
default-information originate and default-information originate always ???
Uttkap
Adding 1 more question to this question ::
Hi Uttkap...
There is no such command in
BGP - default-information originate always"... this is for OSPF...
In OSPF the
will advertise a default route when such a route is present in the RIB
will make the router advertise a default route regardless of the presence of a default route in the router - hence it ALWAYS originates a default route...
