difference between ip base and ipservices for ASR1001?
dcarr3311
Can someone point me to the document or explain to me the differences in the Software images for the ASR1001 routers.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Do you have an active contract that allows access to Cisco's Feature Navigator?
Joseph W. Doherty
Disclaimer
Posting
I have access to Cisco´s Feature Navigator, but when you make a search by ASR1001 platform, and after you choose in "Release" drop box the specific IOS XE version and then in "Feature Set/License(s)" drop box only appear two options: IOS XE UNIVERSAL or IOS XE UNIVERSAL-NO ENCRYPTION. So, you can not compare or know the difference of ip_base and ip_services for ASR1001.
Best regards,
Edward
dcarr3311
I do have access to the Feature Navigator, that works .. thanks!!
