Difference between ping and traceroute actions.
REDDOUG53
In a lab enviroment I was experimenting with acl's and inspections. I could ping a destination with no problem but when trying to use traceroute to the same destination it would fail. Access list I was using was          access-list 101 permit icmp any any echo-reply log
        access-list 101 permit tcp any any www established log
                                            Inspect rules were                        ip inspect name myrules tcp audit-trail on
        ip inspect name myrules udp audit-trail on
        ip inspect name myrules icmp audit-trail on
        ip inspect name myrules http audit-trail on
        ip inspect name myrules ftp audit-trail on
Trying figure out why ping would work and not traceroute. I am pinging accross a vpn tunnel to another router. Access list and inspection rules applied to the inbound port between tunnel router and destination router.
I am a CCNP student at local college.
Thaks, Doug
6 Replies 6
marikakis
Level 7
Level 7
Please have a look at the following URL about how traceroute works:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml#traceroute
If I understand your setup correctly, then I think you need at least the following ACEs included in the ACL:
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
I used you acl's and was able to successfully use the traceroute command.
Thanks, Doug
Hi Doug,
That's good news! Thanks for taking the time to provide feedback about the outcome.
Kind Regards,
Maria
also note Cisco devices are sending UDP packets when running tracert command:
http://www.cisco.com/en/US/tech/tk364/technologies_tech_note09186a00801ae32a.shtml
BR,
Milan
Hi Milan,
You are right. In this case there was a single ACL reported to exist, it would permit echo-reply (so ping worked), and it was applied to some inbound port. For that reason I thought the problem was probably in the return path and suggested only the minimum required additional configuration for traceroute to work as well. What needs to be included in the ACLs depends on the direction the ACL is applied (in/out of interface).
Kind Regards,
Maria
Edit: I forgot to mention that the direction of the traceroute is also part of the game.
REDDOUG53
Thanks, I will give it a try Monday.
Doug
