difference between SIP200 and SIP400
CATYO
Hello.
Is there anyone who can explain what exactly BIG difference between SIP200 and SIP400 ?
They have same four bays, support almost same wan interface cards.
Please help me : )
Reza Sharifi
The difference is mainly speed:
The Cisco 7600 series router is an edge aggregation router, and the SIPs provide a cost-effective solution for customers seeking moderate- to high-port density and line rate services:
The Cisco 7600 SIP-200 provides WAN edge aggregation through lower-speed and low-density SPAs for network environments requiring regional office connectivity to headquarters, or collapsed LAN/WAN deployment.
The Cisco 7600 SIP-400 provides higher-speed, high-density link aggregation for network environments requiring leased line and metro aggregation.
The Cisco 7600 SIP-600 provides a high-speed interface for WANs and metro aggregation.
link:
http://www.cisco.com/en/US/products/hw/routers/ps368/module_installation_and_configuration_guides_chapter09186a008044013b.html#wp1063979
"The difference is mainly speed:"
Sometimes cost too.  ;)
You are absolutely correct Joe.
Cost is always is factor :)
Reza
Thank you : )
