Differences between sintax "SHDSL0" and "SHDSL0/0/0"
acomito_cisco
Until you have single WAN, the problem doesn't exist;
but when you have to configure multiple WANs, born the issue.
In specific I'm speaking about the CISCO888-EA-K9.
System image file is "flash:c800-universalk9-mz.SPA.153-2.T.bin"
Normally you can add a controller SHDSL 0 or SHDSL 0/0/0 (although the ios onboard doesn't support the last sintax);
I have a conf the shows how another 888 is configured with SHDSL 0/0/0 + SHDSL 0/1/0, but I can't do the same with SHDSL 0 + SHDSL 0.1
     Router(config)#controller shDSL 0.1
     % Invalid input detected at '^' marker.
     Router(config)#controller shDSL 0/1/0
Where is my error?
Thanks for your support.
paolo bevilacqua
I don't see how you can add another controller or interface. 880 routers are fixed configuration.
Salve Paolo,
mi sono fato inoltrare una running-config da Wind (Provider in questione), che mostra:
license udi pid C888EA-K9 sn xxx
license boot module c800 level advipservices
controller SHDSL 0/0/0
mode efm
dsl-group 0 pairs 0
controller SHDSL 0/1/0
mode efm
dsl-group 0 pairs 0
interface Ethernet0/0/0
description 2Mb shdsl ULL xxx
no ip address
no shut
interface Ethernet0/0/0.3909
description efm
encapsulation dot1Q 3909
ip address x.x.x.x 255.255.255.252
interface Ethernet0/1/0
no ip address
no shut
interface Ethernet0/1/0.3406
description efm
encapsulation dot1Q 3406
interface Vlan1
ip address x.x.x.x 255.255.255.248
ip virtual-reassembly in
That config is not from an 880 router.
You need to use controller and interface numbers as your router have.
