Differences in IOS
lars
Hi there
Whats the actual difference in the 3 versions of Cisco 7301 router, when you consider the feature licenses.
What is ment by "broadband aggregation feature"?
pkhatri
Level 11
Level 11
The broadband aggregation licence allows you to terminate L2TP sessions and hence a large number of PPP sessions on the router. If you are not using this BRAS functionality, you do not need this feature.
HTH,
Paresh.
