Different next-hop
iores
Level 3
Level 3
In routing table and output of ip cef command I can see the next-hop, e.g. 10.10.10.1.
However, when I do the traceroute towards the sam destinatiom I see that next-hop is 10.10.10.2.
How is that possible? The outgoing port from the local device is the same.
M02@rt37
Hello @iores,
When you perform a traceroute from the local device to the destination, it shows the path that the return traffic is taking. In this case, the traceroute is likely displaying the path taken by the return traffic, which is why you're seeing a different next-hop IP address (10.10.10.2) in the traceroute output compared to the routing table.
This behavior is not uncommon, especially in networks with multiple paths, load balancing.
Best regards
