Differential Clock Recovery
dfauluchi
Hi!
I'm testing ACR and DCR using an ASR9k on one side and a ASR920 on the other side. Theres a SAToP between them and each end connects to a E1.
ACR seems to be Ok, but when I go to DCR I see 2 issues:
- I can't find how to configure Differential clock Tx on ASR920. Is it supported?
- When I configure it the other way round: Differential clock Tx is configured on ASR9K and recover on ASR920 all output traffic is dropped on CEM interfaces due to malformed packets.
Any ideas?
Thanks in advance!
the only reference guides I could find are linked below, not sure if that is in any way useful...
https://www.cisco.com/c/en/us/td/docs/routers/asr903/software/guide/cem/16-12-1/b-cem-ds1-xe-16-12-1-asr900.html
Mark Elsen
 Ref : https://www.cisco.com/c/dam/en/us/td/docs/routers/asr920/compatibility/matrix/Compatibility-Matrix-ASR920.pdf
 Look for the Feature Compatibility Matrix for the Cisco ASR920 Series Aggregation Services Routers , and or lookup differential with find in your browser.
 M.
