Digital Modems MICA-6DM
hello, I have problem with modems Digital MICA-6M , the modems autentication at user ok, but only work during 20 minutes and can not transmit and can not hang up.
What should I do to fix this?
please check the attachment
b.hsu
Level 5
Level 5
Digital modems are available as MICA, NextPort, and Microcom. However, the older Microcom digital modem cards are normally only seen in the AS5200. In order to achieve the desired connectivity between client and server modems, it is important to be aware of which server modems support which modulations with which client modems running which versions of firmware
