DISABLE EIGRP network advertisement
ougwuoke
I need some help here!!! I need to disable EIGRP network advertisement with out using "no router eigrp 1025"
mounir.mohamed
Level 7
Level 7
A lot of filtering methods can be used, but it's depending on your design and requirements
For example, you can filter all or partial inbound / outbound routes via distribute-list
Router (config-router)#distribute-list 10 in atm1/0
Pls rate helpful posts.
Best Regards,
Mounir Mohamed
mounir.mohamed
Level 7
Level 7
Best Regards,
Mounir Mohamed
