Disable intervlan routing between two vlans
ragonrenra
Question
Hey there,
we are having an IT debt made by previous workers and we need to fix that.
Following Situation:
Switch config
VLAN 10 is our Client Network
VLAN 20 is our Server Network
Intervlan Routing is active
Path
User > Access-Switch > Core-Switch > Dell Switch > ESXI-Host > Virtualized Server
Internal users are able to communicate to servers without passing through our firewall. We want to forward every client > server traffic through our firewall in order to set necessary security rules. Removing VLAN 20 would cause a lot of problems. How can we disable intervlan routing between those two vlan in order to route traffic to our fw? Any ideas or other suggestions?
only make the Server and Clinet GW is FW, this done by DHCP, make DHCP push FW IP to client and server
MHM
Martin L
Who is doing Intervlan Routing ? your Core switch L3 switch , right/
You have some options: disable inter-vlan routing for all vlans on Cisco switch with no ip routing command; remove default gateway from PCs (prevents reaching remote networks), use ACLs or Vlan ACLs (VACLs, aka Vlan access maps) - the fancy way of doing things.
Regards, ML
**Please Rate All Helpful Responses **
