Disable onboard ISDN BRI
weehengno1
Dear all,
May i know how to disable onboard ISDN BRI0 S/T. This is because i add in another ISDN BRI module in WIC slot. The purpose of adding in another isdn module because the onboard ISDN BRI port doesn't work which previously was working fine.
Thank you.
IOS (tm) 1600 Software (C1600-NY-M), Version 12.0(6), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Wed 11-Aug-99 01:35 by phanguye
Image text-base: 0x02005000, data-base: 0x024BA93C
interface BRI0
no ip address
no ip directed-broadcast
shutdown
interface BRI0
no ip address
shutdown
pushkar1782
I think just shutting the interface would do .. Just add another card in wic slot and configure the new interface . That would simply work.
I think this should help .
TC
prs
I did that..but it doesn't work. The router has 2 int bri0. What ever i configure is always on the onboard isdn bri interface. Suppose one is int bri0 and the other one is int bri1.
