Disable SPI 891F router
asilva
What is the command to disable SPI on 891F router? I need to disable it for VOIP
Philip D'Ath
no ip nat service sip udp port 5060
Thank you for the feedback, but I already was able to disable SIP ALG. The issue is with our VOIP system and I have been informed that SPI (Stateful Packet Inspection) may be the cause of our phone issues. I do not know how to check for this or disable it for the appropriate port.
