Disable the Application Visability on Cisco 1117-4p
Martin
I have set this router up and turned on the Application Visability to see what it was like and it seriously slowed it down, so now wish to disable it. I cant see anywhere in the WEB-ui nor CLI where to disable it.
Many thanks
Torbjørn
The term "Application Visibility" is a bit vague. How did you enable it? Can you post the config?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Martin
I factory reset it and started again
