Disabling NAT-T on a 2811 router
dhopper82
All,
I have a couple of 2811 routers that we're trying to connect up together over an IPSEC tunnel. We are trying to disable NAT-T on them so we'll just be passing UPD 500 and protocol 50 traffic (instead of udp 4500). Is there a way to do this? We are running an advanced security IOS.
andrew.prince
Level 10
Level 10
Try:-
no crypto ipsec nat-transparency udp-encapsulation
HTH>
andrew.prince
Level 10
Level 10
Try:-
HTH>
That worked. Thanks!
np - glasd to help
slmansfield
Level 4
Level 4
I think you just have to enter the following command in global configuration mode.
