Distance eigrp 90 90 WS-6500 VSS
jesusresendiz
I have a client that has WS-6500 in VSS with NSF. By deleting the command distance eigrp 90 90, the neighboring devices resynchronized their eigrp adyacency. After this, the metrics appeared as infinity, causing an instability in the network. Why this happen?
Does i need to execute a clear ip eigrp?
WS-6500-VSS#show ip eigrp topology 10.1.1.0/24
EIGRP-IPv4 Topology Entry for AS(10)/ID(10.1.2.1) for 10.1.1.0/24
  State is Active, Query origin flag is 1, 1 Successor(s), FD is 3328512
Waiting for 1 replies
  Descriptor Blocks:
  10.1.4.254 (GigabitEthernet1/1/1), from 10.1.4.254, Send flag is 0x0
      Composite metric is (Infinity/Infinity), route is Internal
      Vector metric:
        Minimum bandwidth is 1000000 Kbit
        Total delay is 281438776 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
Richard Burts
Part of the explanation is easy. The metric went to Infinity because the route is in the active state. The router has sent a query to its neighbors about this route and is waiting for 1 response. This condition is referred to as Stuck In Active. So the real question is why is the router not receiving a response to its query? We need to know more about the network environment to be able to answer that.
Rick
Rick
