09-09-2011 10:21 PM - edited 03-04-2019 01:33 PM
Dear All,
EIGRP Peer routers are WHQ (100.31.17.154) and TOL (100.31.17.153). Both are having full adjanceny and working fine.
I want to tweak the metric of directly connected routes on TOL before it advertise to WHQ.. Below are my configs and I see hits on my access-list but there are no changes on the peer's eigrp topology table.
10.1.0.128/28, 100.172.122.0/24 , 100.172.122.0/24 are directly connected routes on TOL router.
Please assist..
on TOL:
router eigrp 1
network 10.13.0.0 0.0.255.255
network 10.0.0.0
network 100.0.0.0
distribute-list route-map AIRPORT_Subnet out Serial0/0/0:1.100
no auto-summary
eigrp stub connected summary
route-map AIRPORT_Subnet permit 10
match ip address 10
set metric 2000 5000 255 1 1500
Standard IP access list 10
10 permit 10.1.0.128, wildcard bits 0.0.0.15 (3 matches)
20 permit 100.172.122.0, wildcard bits 0.0.0.255 (3 matches)
30 permit 100.171.121.0, wildcard bits 0.0.0.255 (3 matches)
on WHQ
WHQ#show ip eigrp topology 100.171.121.0/24
IP-EIGRP (AS 1): Topology entry for 100.171.121.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2221568
Routing Descriptor Blocks:
100.31.200.2 (Serial2/0.100), from 100.31.200.2, Send flag is 0x0
Composite metric is (2221568/1837568), Route is Internal
Vector metric:
Minimum bandwidth is 1500 Kbit
Total delay is 20120 microseconds
Reliability is 255/255
Load is 44/255
Minimum MTU is 1400
Hop count is 4
100.31.17.154 (Serial0/1/1:1.100), from 100.31.17.154, Send flag is 0x0
Composite metric is (2306560/153600), Route is Internal
Vector metric:
Minimum bandwidth is 1536 Kbit
Total delay is 25000 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 1
Solved! Go to Solution.
09-10-2011 01:53 AM
Please try to use EIGRP offset-list and set metric and direction
as distribute-list is more for filtering
If helpful rate
09-10-2011 01:53 AM
If helpful rate
09-10-2011 02:05 AM
I do not wanted to make any changes on WHQ router..
10.1.0.128/28, 100.172.121.0/24 , 100.172.122.0/24 are directly connected routes on TOL router. I wanted WHQ router to prefer TOL router as its next hop..
Can we set metric for these connected routes using any combitations like eigrp offset list, route-map, prerfix-list, distribute-list, access-list etc.. ?
09-10-2011 02:11 AM
Using eigrp Offset can i decrease the directly connected routes metric value before it advertise to its peer ?
09-10-2011 03:00 AM
hi,
no with an offset-list you can only increase the metric.
Regards.
Alain.
09-10-2011 02:36 AM
I did it using offset list..I incremented the metric through the other path..I could clear ip eigrp neighbhor and see the results in next immediate neighbhor..
It is not possible to clear neighbhorsip on all other router..How long this would take to reflect on all other routers ?
router eigrp 1
offset-list 10 out 10000 Tunnel1
09-10-2011 02:45 AM
Not long EIGRP convergence is fast
Glad it's working
Please rate this discussion as resolved
