Diverse BGP on Campus - Issues
rdboyd
We have two BGP handoffs within the Data Center that is load-balancing and working fine. We have a MAN with 10 gig ethernet between the Campus and a remote office. We just installed a new BGP router and handoff at the Campus and running into obvious routing issues. We are experiencing routing loops and asymetrical routes. Here is an excerpt from our DC MPLS router:
router eigrp x
redistribute static
redistribute bgp 1234 route-map bgp_all
network 10.48.x.10 0.0.0.0
network 10.48.x.x 0.0.0.3
default-metric 10000000 100 255 1 1500
no auto-summary
router bgp 1234
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
network 10.48.0.0 mask 255.255.224.0
network 10.48.x.0 mask 255.255.255.0
network 10.50.0.0 mask 255.255.0.0
aggregate-address 10.48.0.0 255.255.224.0 summary-only
aggregate-address 10.50.0.0 255.255.0.0 summary-only
redistribute eigrp x route-map bgp_all
neighbor x.x.x.x remote-as 4321
neighbor x.x.x.x soft-reconfiguration inbound
no auto-summary
Here is the configuration for the Campus router:
router eigrp x
network 10.48.x.x 0.0.0.0
network 10.50.x.x 0.0.0.7
network 10.50.x.x 0.0.0.3
no auto-summary
router bgp 12345
no synchronization
network x.x.x.x mask 255.255.255.252
neighbor x.x.x.x remote-as 43210
no auto-summary
If we are at the campus, we to locally go out the WAN for MPLS sites. If at the DC, we would locally go out the local MPLS routers. The remote sites would need to come back to the same router as they went out on. The complicating factor is the EIGRP between the two routers and the speed/delay preference.
Ricky Boyd
mdaaxcess
why do you, in your bgp have a network 0.0.0.0 ? + please paste the route-map used in your bgp and eigrp
The 'network 0.0.0.0' was recommended by our ISP. The 'default-information originate' command should accomplish the same thing.
As far as the route-map, this is just used for our load balancer along with WCCP.
Rick
