DMVPN dua HUB issue, one tunnel doesnt work
OMAR CANDARAVE
Hi all,
I have an issue with a Dual DMVPN scenario.
I have 2 Hubs and multiples spokes, each spoke has 2 tunnels one to each HUB.
I am having issues with a spoke but only with one tunnel:
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4            80.188.29.210  YES NVRAM  up                    up
Tunnel1                    10.24.170.58    YES NVRAM  up                    up
Tunnel2                    10.32.170.58    YES NVRAM  up                    up
Vlan1                      10.24.141.3     YES NVRAM  up                    up
czprab01#sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
80.188.29.210   216.40.52.7     QM_IDLE           2113 ACTIVE              <-------------- Tunnel 1 (working)
216.40.48.53    80.188.29.210   MM_KEY_EXCH       2780 ACTIVE
216.40.48.53    80.188.29.210   MM_KEY_EXCH       2779 ACTIVE
216.40.48.53    80.188.29.210   MM_NO_STATE       2778 ACTIVE (deleted)
216.40.48.53    80.188.29.210   MM_NO_STATE       2777 ACTIVE (deleted)
IPv6 Crypto ISAKMP SA
czprab01#sh crypto ipsec sa
interface: Tunnel1
    Crypto map tag: Tunnel1-head-0, local addr 80.188.29.210
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (80.188.29.210/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (216.40.52.7/255.255.255.255/47/0)
   current_peer 216.40.52.7 port 4500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 3955556, #pkts encrypt: 3955556, #pkts digest: 3955556
    #pkts decaps: 4334117, #pkts decrypt: 4334117, #pkts verify: 4334117
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 1618
     local crypto endpt.: 80.188.29.210, remote crypto endpt.: 216.40.52.7
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet4
     current outbound spi: 0x209DAC2C(547204140)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0x45E07928(1172338984)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Transport UDP-Encaps, }
        conn id: 39, flow_id: Onboard VPN:39, sibling_flags 80000006, crypto map: Tunnel1-head-0
        sa timing: remaining key lifetime (k/sec): (4459162/777)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 40, flow_id: Onboard VPN:40, sibling_flags 80000006, crypto map: Tunnel1-head-0
        sa timing: remaining key lifetime (k/sec): (4461679/777)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
interface: Tunnel2
    Crypto map tag: Tunnel2-head-0, local addr 80.188.29.210
   remote ident (addr/mask/prot/port): (216.40.48.53/255.255.255.255/47/0)
   current_peer 216.40.48.53 port 500
     PERMIT, flags={origin_is_acl,ipsec_sa_request_sent}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #send errors 266, #recv errors 0
     local crypto endpt.: 80.188.29.210, remote crypto endpt.: 216.40.48.53
     current outbound spi: 0x0(0)
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
DEBUG on the spoke:
czprab01#sh debugging
Cryptographic Subsystem:
  Crypto ISAKMP Error debugging is on
  Crypto IPSEC Error debugging is on
czprab01#
*Nov  5 02:38:24 Winter: insert of map into mapdb AVL failed, map + ace pair already exists on the mapdb
216.40.48.53    80.188.29.210   MM_KEY_EXCH       2787 ACTIVE
216.40.48.53    80.188.29.210   MM_KEY_EXCH       2786 ACTIVE
*Nov  5 02:39:24 Winter: ISAKMP:(2786):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 216.40.48.53)
*Nov  5 02:39:54 Winter: ISAKMP:(2787):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 216.40.48.53)
*Nov  5 02:40:28 Winter: ISAKMP:(2788):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 216.40.48.53)
*Nov  5 02:40:54 Winter: ISAKMP:(2789):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 216.40.48.53)
*Nov  5 02:41:24 Winter: ISAKMP:(2790):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 216.40.48.53)
configuration of the tunnels:
czprab01#sh runn int tunn1
Building configuration...
Current configuration : 405 bytes
interface Tunnel1
bandwidth 1000
ip address 10.24.170.58 255.255.255.0
ip mtu 1352
ip flow ingress
ip nhrp authentication donttell
ip nhrp map 10.24.170.1 216.40.52.7
ip nhrp network-id 169
ip nhrp holdtime 300
ip nhrp nhs 10.24.170.1
ip tcp adjust-mss 1200
delay 1000
tunnel source FastEthernet4
tunnel destination 216.40.52.7
tunnel key 100000
tunnel protection ipsec profile CHEP
end
czprab01#sh runn int tunn2
Current configuration : 406 bytes
interface Tunnel2
bandwidth 256
ip address 10.32.170.58 255.255.255.0
ip mtu 1352
ip flow ingress
ip nhrp map 10.32.170.1 216.40.48.53
ip nhrp network-id 170
ip nhrp nhs 10.32.170.1
delay 1500
tunnel destination 216.40.48.53
tunnel key 100001
end
I tried to shut down the tunnel2 for a while but no luck
I did clear crypto sa peer XXXX and no luck
any suggestion please?
THANK YOU
Vinayaka Raman
https://supportforums.cisco.com/thread/256417
please take a look at the above..
Vinayak
Regards Vinayak
7 Replies 7
Vinayaka Raman
Vinayak
Regards Vinayak
Hello, Omar.
Please provide output for "debug crypto isakmp" and " sh ip route 216.40.48.53"
OMAR CANDARAVE
This is the output of the debugÑ
czprab01#
*Nov  7 01:32:53 Winter: %SYS-5-CONFIG_I: Configured from console by netman on vty0 (10.32.1.22)
*Nov  7 01:32:55 Winter: %LINK-3-UPDOWN: Interface Tunnel2, changed state to up
*Nov  7 01:32:55 Winter: ISAKMP:(0): SA request profile is (NULL)
*Nov  7 01:32:55 Winter: ISAKMP: Created a peer struct for 216.40.48.53, peer port 500
*Nov  7 01:32:55 Winter: ISAKMP: New peer created peer = 0x84F1B738 peer_handle = 0x80000D08
*Nov  7 01:32:55 Winter: ISAKMP: Locking peer struct 0x84F1B738, refcount 1 for isakmp_initiator
*Nov  7 01:32:55 Winter: ISAKMP: local port 500, remote port 500
*Nov  7 01:32:55 Winter: ISAKMP: set new node 0 to QM_IDLE
*Nov  7 01:32:55 Winter: ISAKMP:(0):insert sa successfully sa = 84F2BDD4
*Nov  7 01:32:55 Winter: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
*Nov  7 01:32:55 Winter: ISAKMP:(0):found peer pre-shared key matching 216.40.48.53
*Nov  7 01:32:55 Winter: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
*Nov  7 01:32:55 Winter: ISAKMP:(0): constructed NAT-T vendor-07 ID
*Nov  7 01:32:55 Winter: ISAKMP:(0): constructed NAT-T vendor-03 ID
*Nov  7 01:32:55 Winter: ISAKMP:(0): constructed NAT-T vendor-02 ID
*Nov  7 01:32:55 Winter: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Nov  7 01:32:55 Winter: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
*Nov  7 01:32:55 Winter: ISAKMP:(0): beginning Main Mode exchange
*Nov  7 01:32:55 Winter: ISAKMP:(0): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_NO_STATE
*Nov  7 01:32:55 Winter: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Nov  7 01:32:55 Winter: ISAKMP (0): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_NO_STATE
*Nov  7 01:32:55 Winter: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Nov  7 01:32:55 Winter: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_I_MM2
*Nov  7 01:32:55 Winter: ISAKMP:(0): processing SA payload. message ID = 0
*Nov  7 01:32:55 Winter: ISAKMP:(0): processing vendor id payload
*Nov  7 01:32:55 Winter: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
*Nov  7 01:32:55 Winter: ISAKMP (0): vendor ID is NAT-T RFC 3947
*Nov  7 01:32:55 Winter: ISAKMP:(0): local preshared key found
*Nov  7 01:32:55 Winter: ISAKMP : Scanning profiles for xauth ...
*Nov  7 01:32:55 Winter: ISAKMP:(0):Checking ISAKMP transform 1 against priority 10 policy
*Nov  7 01:32:55 Winter: ISAKMP:      encryption 3DES-CBC
*Nov  7 01:32:55 Winter: ISAKMP:      hash MD5
*Nov  7 01:32:55 Winter: ISAKMP:      default group 1
*Nov  7 01:32:55 Winter: ISAKMP:      auth pre-share
*Nov  7 01:32:55 Winter: ISAKMP:      life type in seconds
*Nov  7 01:32:55 Winter: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
*Nov  7 01:32:55 Winter: ISAKMP:(0):atts are acceptable. Next payload is 0
*Nov  7 01:32:55 Winter: ISAKMP:(0):Acceptable atts:actual life: 0
*Nov  7 01:32:55 Winter: ISAKMP:(0):Acceptable atts:life: 0
*Nov  7 01:32:55 Winter: ISAKMP:(0):Fill atts in sa vpi_length:4
*Nov  7 01:32:55 Winter: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
*Nov  7 01:32:55 Winter: ISAKMP:(0):Returning Actual lifetime: 86400
*Nov  7 01:32:55 Winter: ISAKMP:(0)::Started lifetime timer: 86400.
*Nov  7 01:32:55 Winter: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Nov  7 01:32:55 Winter: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM2
*Nov  7 01:32:55 Winter: ISAKMP:(0): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_SA_SETUP
*Nov  7 01:32:55 Winter: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Nov  7 01:32:55 Winter: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM3
*Nov  7 01:32:55 Winter: ISAKMP (0): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_SA_SETUP
*Nov  7 01:32:55 Winter: ISAKMP:(0):Old State = IKE_I_MM3  New State = IKE_I_MM4
*Nov  7 01:32:55 Winter: ISAKMP:(0): processing KE payload. message ID = 0
*Nov  7 01:32:55 Winter: ISAKMP:(0): processing NONCE payload. message ID = 0
*Nov  7 01:32:55 Winter: ISAKMP:(2308): processing vendor id payload
*Nov  7 01:32:55 Winter: ISAKMP:(2308): vendor ID is Unity
*Nov  7 01:32:55 Winter: ISAKMP:(2308): vendor ID is DPD
*Nov  7 01:32:55 Winter: ISAKMP:(2308): speaking to another IOS box!
*Nov  7 01:32:55 Winter: ISAKMP:received payload type 20
*Nov  7 01:32:55 Winter: ISAKMP (2308): His hash no match - this node outside NAT
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Old State = IKE_I_MM4  New State = IKE_I_MM4
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Send initial contact
*Nov  7 01:32:55 Winter: ISAKMP:(2308):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
*Nov  7 01:32:55 Winter: ISAKMP (2308): ID payload
        next-payload : 8
        type         : 1
        address      : 80.188.29.210
        protocol     : 17
        port         : 0
        length       : 12
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Total payload length: 12
*Nov  7 01:32:55 Winter: ISAKMP:(2308): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Sending an IKE IPv4 Packet.
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Nov  7 01:32:55 Winter: ISAKMP:(2308):Old State = IKE_I_MM4  New State = IKE_I_MM5
*Nov  7 01:32:56 Winter: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel2, changed state to up
czprab01#
czprab01#
*Nov  7 01:33:05 Winter: ISAKMP:(2308): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:05 Winter: ISAKMP (2308): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
*Nov  7 01:33:05 Winter: ISAKMP:(2308): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:05 Winter: ISAKMP:(2308):Sending an IKE IPv4 Packet.
*Nov  7 01:33:15 Winter: ISAKMP:(2308): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:15 Winter: ISAKMP (2308): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Nov  7 01:33:15 Winter: ISAKMP:(2308): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:15 Winter: ISAKMP:(2308):Sending an IKE IPv4 Packet.
czprab01#
czprab01#
czprab01#
czprab01#
*Nov  7 01:33:25 Winter: ISAKMP:(0): SA request profile is (NULL)
*Nov  7 01:33:25 Winter: ISAKMP: Created a peer struct for 216.40.48.53, peer port 500
*Nov  7 01:33:25 Winter: ISAKMP: New peer created peer = 0x838FB5D8 peer_handle = 0x80000D0F
*Nov  7 01:33:25 Winter: ISAKMP: Locking peer struct 0x838FB5D8, refcount 1 for isakmp_initiator
*Nov  7 01:33:25 Winter: ISAKMP: local port 500, remote port 500
*Nov  7 01:33:25 Winter: ISAKMP: set new node 0 to QM_IDLE
*Nov  7 01:33:25 Winter: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 8390F81C
*Nov  7 01:33:25 Winter: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
*Nov  7 01:33:25 Winter: ISAKMP:(0):found peer pre-shared key matching 216.40.48.53
*Nov  7 01:33:25 Winter: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
*Nov  7 01:33:25 Winter: ISAKMP:(0): constructed NAT-T vendor-07 ID
*Nov  7 01:33:25 Winter: ISAKMP:(0): constructed NAT-T vendor-03 ID
*Nov  7 01:33:25 Winter: ISAKMP:(0): constructed NAT-T vendor-02 ID
*Nov  7 01:33:25 Winter: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Nov  7 01:33:25 Winter: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
*Nov  7 01:33:25 Winter: ISAKMP:(0): beginning Main Mode exchange
*Nov  7 01:33:25 Winter: ISAKMP:(0): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_NO_STATE
*Nov  7 01:33:25 Winter: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Nov  7 01:33:25 Winter: ISAKMP (0): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_NO_STATE
*Nov  7 01:33:25 Winter: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Nov  7 01:33:25 Winter: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_I_MM2
*Nov  7 01:33:25 Winter: ISAKMP:(0): processing SA payload. message ID = 0
*Nov  7 01:33:25 Winter: ISAKMP:(0): processing vendor id payload
*Nov  7 01:33:25 Winter: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
*Nov  7 01:33:25 Winter: ISAKMP (0): vendor ID is NAT-T RFC 3947
*Nov  7 01:33:25 Winter: ISAKMP:(0): local preshared key found
*Nov  7 01:33:25 Winter: ISAKMP : Scanning profiles for xauth ...
*Nov  7 01:33:25 Winter: ISAKMP:(0):Checking ISAKMP transform 1 against priority 10 policy
*Nov  7 01:33:25 Winter: ISAKMP:      encryption 3DES-CBC
*Nov  7 01:33:25 Winter: ISAKMP:      hash MD5
*Nov  7 01:33:25 Winter: ISAKMP:      default group 1
*Nov  7 01:33:25 Winter: ISAKMP:      auth pre-share
*Nov  7 01:33:25 Winter: ISAKMP:      life type in seconds
*Nov  7 01:33:25 Winter: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
*Nov  7 01:33:25 Winter: ISAKMP:(0):atts are acceptable. Next payload is 0
*Nov  7 01:33:25 Winter: ISAKMP:(0):Acceptable atts:actual life: 0
*Nov  7 01:33:25 Winter: ISAKMP:(0):Acceptable atts:life: 0
*Nov  7 01:33:25 Winter: ISAKMP:(0):Fill atts in sa vpi_length:4
*Nov  7 01:33:25 Winter: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
*Nov  7 01:33:25 Winter: ISAKMP:(0):Returning Actual lifetime: 86400
*Nov  7 01:33:25 Winter: ISAKMP:(0)::Started lifetime timer: 86400.
*Nov  7 01:33:25 Winter: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Nov  7 01:33:25 Winter: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM2
*Nov  7 01:33:25 Winter: ISAKMP:(0): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_SA_SETUP
*Nov  7 01:33:25 Winter: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Nov  7 01:33:25 Winter: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM3
*Nov  7 01:33:25 Winter: ISAKMP (0): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_SA_SETUP
*Nov  7 01:33:25 Winter: ISAKMP:(0):Old State = IKE_I_MM3  New State = IKE_I_MM4
*Nov  7 01:33:25 Winter: ISAKMP:(0): processing KE payload. message ID = 0
*Nov  7 01:33:25 Winter: ISAKMP:(0): processing NONCE payload. message ID = 0
*Nov  7 01:33:25 Winter: ISAKMP:(2309): processing vendor id payload
*Nov  7 01:33:25 Winter: ISAKMP:(2309): vendor ID is Unity
*Nov  7 01:33:25 Winter: ISAKMP:(2309): vendor ID is DPD
*Nov  7 01:33:25 Winter: ISAKMP:(2309): speaking to another IOS box!
*Nov  7 01:33:25 Winter: ISAKMP:received payload type 20
*Nov  7 01:33:25 Winter: ISAKMP (2309): His hash no match - this node outside NAT
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Old State = IKE_I_MM4  New State = IKE_I_MM4
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Send initial contact
*Nov  7 01:33:25 Winter: ISAKMP:(2309):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
*Nov  7 01:33:25 Winter: ISAKMP (2309): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 0
        length       : 12
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Total payload length: 12
*Nov  7 01:33:25 Winter: ISAKMP:(2309): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Sending an IKE IPv4 Packet.
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Nov  7 01:33:25 Winter: ISAKMP:(2309):Old State = IKE_I_MM4  New State = IKE_I_MM5
*Nov  7 01:33:25 Winter: ISAKMP:(2308): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:25 Winter: ISAKMP (2308): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
*Nov  7 01:33:25 Winter: ISAKMP:(2308): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:25 Winter: ISAKMP:(2308):Sending an IKE IPv4 Packet.
czprab01#
*Nov  7 01:33:35 Winter: ISAKMP:(2309): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:35 Winter: ISAKMP (2309): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
*Nov  7 01:33:35 Winter: ISAKMP:(2309): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:35 Winter: ISAKMP:(2309):Sending an IKE IPv4 Packet.
*Nov  7 01:33:35 Winter: ISAKMP:(2308): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:35 Winter: ISAKMP (2308): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
*Nov  7 01:33:35 Winter: ISAKMP:(2308): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:35 Winter: ISAKMP:(2308):Sending an IKE IPv4 Packet.
*Nov  7 01:33:45 Winter: ISAKMP:(2309): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:45 Winter: ISAKMP (2309): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*Nov  7 01:33:45 Winter: ISAKMP:(2309): sending packet to 216.40.48.53 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
*Nov  7 01:33:45 Winter: ISAKMP:(2309):Sending an IKE IPv4 Packet.
*Nov  7 01:33:45 Winter: ISAKMP:(2308): retransmitting phase 1 MM_KEY_EXCH...
*Nov  7 01:33:45 Winter: ISAKMP (2308): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
czprab01#sh ip route 216.40.48.53
Routing entry for 216.40.48.53/32
  Known via "static", distance 1, metric 0
  Routing Descriptor Blocks:
  * 80.188.29.209, via FastEthernet4
      Route metric is 0, traffic share count is 1
czprab01#ping 216.40.48.53
Sending 5, 100-byte ICMP Echos to 216.40.48.53, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 132/134/140 ms
Thank you
Hello, Omar.
Looks like some issue with NAT-T. But it's strange that router detects NAT even though you are using piblic addresses.
Take a look at the link provided by Raman.
PS: check you inbound ACLs on both side - do they permit udp 4500?
PS2: do you have the same debug output from the other side?
OMAR CANDARAVE
Hi Mikhailovsky,
I tried what in the link says:
command
crypto ipsec nat-transparency spi-matching
in both sides int this is the result:
czprab01#sh cryp session
Crypto session current status
Interface: Tunnel1
Session status: UP-ACTIVE
Peer: 216.40.52.7 port 4500
  IKE SA: local 80.188.29.210/4500 remote 216.40.52.7/4500 Active
  IPSEC FLOW: permit 47 host 80.188.29.210 host 216.40.52.7
        Active SAs: 2, origin: crypto map
Interface: Tunnel2
Session status: UP-IDLE      <----------------------------------------
Peer: 216.40.48.53 port 500
  IKE SA: local 80.188.29.210/500 remote 216.40.48.53/500 Active
  IPSEC FLOW: permit 47 host 80.188.29.210 host 216.40.48.53
        Active SAs: 0, origin: crypto map
czprab01#sh cryp isa
czprab01#sh cryp isakmp sa
216.40.48.53    80.188.29.210   QM_IDLE           2458 ACTIVE
216.40.52.7     80.188.29.210   QM_IDLE           2034 ACTIVE
Debug:  (looks like it is trying throught the port 500)
czprab01#
*Nov  7 23:12:24 Winter: %SYS-5-CONFIG_I: Configured from console by netman on vty0 (10.32.1.22)
*Nov  7 23:12:25 Winter: %LINK-3-UPDOWN: Interface Tunnel2, changed state to up
*Nov  7 23:12:25 Winter: ISAKMP:(0): SA request profile is (NULL)
*Nov  7 23:12:25 Winter: ISAKMP: Created a peer struct for 216.40.48.53, peer port 500
*Nov  7 23:12:25 Winter: ISAKMP: New peer created peer = 0x84F60934 peer_handle = 0x8000194B
*Nov  7 23:12:25 Winter: ISAKMP: Locking peer struct 0x84F60934, refcount 1 for isakmp_initiator
*Nov  7 23:12:25 Winter: ISAKMP: local port 500, remote port 500
*Nov  7 23:12:25 Winter: ISAKMP: set new node 0 to QM_IDLE
*Nov  7 23:12:25 Winter: ISAKMP:(0):insert sa successfully sa = 84F5FF70
*Nov  7 23:12:25 Winter: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
*Nov  7 23:12:25 Winter: ISAKMP:(0):found peer pre-shared key matching 216.40.48.53
*Nov  7 23:12:25 Winter: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Nov  7 23:12:25 Winter: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
*Nov  7 23:12:25 Winter: ISAKMP:(0): beginning Main Mode exchange
*Nov  7 23:12:25 Winter: ISAKMP:(0): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_NO_STATE
*Nov  7 23:12:25 Winter: ISAKMP:(0):Sending an IKE IPv4 Packet.
*Nov  7 23:12:25 Winter: ISAKMP (0): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_NO_STATE
*Nov  7 23:12:25 Winter: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Nov  7 23:12:25 Winter: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_I_MM2
*Nov  7 23:12:25 Winter: ISAKMP:(0): processing SA payload. message ID = 0
*Nov  7 23:12:25 Winter: ISAKMP:(0): local preshared key found
*Nov  7 23:12:25 Winter: ISAKMP : Scanning profiles for xauth ...
*Nov  7 23:12:25 Winter: ISAKMP:(0):Checking ISAKMP transform 1 against priority 10 policy
*Nov  7 23:12:25 Winter: ISAKMP:      encryption 3DES-CBC
*Nov  7 23:12:25 Winter: ISAKMP:      hash MD5
*Nov  7 23:12:25 Winter: ISAKMP:      default group 1
*Nov  7 23:12:25 Winter: ISAKMP:      auth pre-share
*Nov  7 23:12:25 Winter: ISAKMP:      life type in seconds
*Nov  7 23:12:25 Winter: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
*Nov  7 23:12:25 Winter: ISAKMP:(0):atts are acceptable. Next payload is 0
*Nov  7 23:12:25 Winter: ISAKMP:(0):Acceptable atts:actual life: 0
*Nov  7 23:12:25 Winter: ISAKMP:(0):Acceptable atts:life: 0
*Nov  7 23:12:25 Winter: ISAKMP:(0):Fill atts in sa vpi_length:4
*Nov  7 23:12:25 Winter: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
*Nov  7 23:12:25 Winter: ISAKMP:(0):Returning Actual lifetime: 86400
*Nov  7 23:12:25 Winter: ISAKMP:(0)::Started lifetime timer: 86400.
*Nov  7 23:12:25 Winter: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Nov  7 23:12:25 Winter: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM2
*Nov  7 23:12:25 Winter: ISAKMP:(0): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_SA_SETUP
*Nov  7 23:12:25 Winter: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Nov  7 23:12:25 Winter: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM3
*Nov  7 23:12:25 Winter: ISAKMP (0): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_SA_SETUP
*Nov  7 23:12:25 Winter: ISAKMP:(0):Old State = IKE_I_MM3  New State = IKE_I_MM4
*Nov  7 23:12:25 Winter: ISAKMP:(0): processing KE payload. message ID = 0
*Nov  7 23:12:25 Winter: ISAKMP:(0): processing NONCE payload. message ID = 0
*Nov  7 23:12:25 Winter: ISAKMP:(2458): processing vendor id payload
*Nov  7 23:12:25 Winter: ISAKMP:(2458): vendor ID is Unity
*Nov  7 23:12:25 Winter: ISAKMP:(2458): vendor ID is DPD
*Nov  7 23:12:25 Winter: ISAKMP:(2458): speaking to another IOS box!
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_I_MM4  New State = IKE_I_MM4
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Send initial contact
*Nov  7 23:12:25 Winter: ISAKMP:(2458):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
*Nov  7 23:12:25 Winter: ISAKMP (2458): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 500
        length       : 12
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Total payload length: 12
*Nov  7 23:12:25 Winter: ISAKMP:(2458): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) MM_KEY_EXCH
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Sending an IKE IPv4 Packet.
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_I_MM4  New State = IKE_I_MM5
*Nov  7 23:12:25 Winter: ISAKMP (2458): received packet from 216.40.48.53 dport 500 sport 500 Global (I) MM_KEY_EXCH
*Nov  7 23:12:25 Winter: ISAKMP:(2458): processing ID payload. message ID = 0
        next-payload : 8
        type         : 1
        address      : 10.32.100.95
        protocol     : 17
        port         : 500
        length       : 12
*Nov  7 23:12:25 Winter: ISAKMP:(0):: peer matches *none* of the profiles
*Nov  7 23:12:25 Winter: ISAKMP:(2458): processing HASH payload. message ID = 0
*Nov  7 23:12:25 Winter: ISAKMP:(2458):SA authentication status:
        authenticated
*Nov  7 23:12:25 Winter: ISAKMP:(2458):SA has been authenticated with 216.40.48.53
*Nov  7 23:12:25 Winter: ISAKMP: Trying to insert a peer 80.188.29.210/216.40.48.53/500/,  and inserted successfully 84F60934.
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_I_MM5  New State = IKE_I_MM6
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_I_MM6  New State = IKE_I_MM6
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_I_MM6  New State = IKE_P1_COMPLETE
*Nov  7 23:12:25 Winter: ISAKMP:(2458):IKE_DPD is enabled, initializing timers
*Nov  7 23:12:25 Winter: ISAKMP:(2458):beginning Quick Mode exchange, M-ID of -1653111772
*Nov  7 23:12:25 Winter: ISAKMP:(2458):QM Initiator gets spi
*Nov  7 23:12:25 Winter: ISAKMP:(2458): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) QM_IDLE
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Node -1653111772, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_QM_READY  New State = IKE_QM_I_QM1
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
*Nov  7 23:12:25 Winter: ISAKMP (2458): received packet from 216.40.48.53 dport 500 sport 500 Global (I) QM_IDLE
*Nov  7 23:12:25 Winter: ISAKMP: set new node 457267733 to QM_IDLE
*Nov  7 23:12:25 Winter: ISAKMP:(2458): processing HASH payload. message ID = 457267733
*Nov  7 23:12:25 Winter: ISAKMP:(2458): processing NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
        spi 366030750, message ID = 457267733, sa = 84F5FF70
*Nov  7 23:12:25 Winter: ISAKMP:(2458): deleting spi 366030750 message ID = -1653111772
*Nov  7 23:12:25 Winter: ISAKMP:(2458):deleting node -1653111772 error TRUE reason "Delete Larval"
*Nov  7 23:12:25 Winter: ISAKMP:(2458):deleting node 457267733 error FALSE reason "Informational (in) state 1"
*Nov  7 23:12:25 Winter: ISAKMP:(2458):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
*Nov  7 23:12:26 Winter: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel2, changed state to up
czprab01#
czprab01#
czprab01#
*Nov  7 23:12:55 Winter: ISAKMP: set new node 0 to QM_IDLE
*Nov  7 23:12:55 Winter: SA has outstanding requests  (local 132.246.0.244 port 500, remote 132.246.0.216 port 500)
*Nov  7 23:12:55 Winter: ISAKMP:(2458): sitting IDLE. Starting QM immediately (QM_IDLE      )
*Nov  7 23:12:55 Winter: ISAKMP:(2458):beginning Quick Mode exchange, M-ID of -2109933165
*Nov  7 23:12:55 Winter: ISAKMP:(2458):QM Initiator gets spi
*Nov  7 23:12:55 Winter: ISAKMP:(2458): sending packet to 216.40.48.53 my_port 500 peer_port 500 (I) QM_IDLE
*Nov  7 23:12:55 Winter: ISAKMP:(2458):Sending an IKE IPv4 Packet.
*Nov  7 23:12:55 Winter: ISAKMP:(2458):Node -2109933165, Input = IKE_MESG_INTERNAL, IKE_INIT_QM
*Nov  7 23:12:55 Winter: ISAKMP:(2458):Old State = IKE_QM_READY  New State = IKE_QM_I_QM1
*Nov  7 23:12:55 Winter: ISAKMP (2458): received packet from 216.40.48.53 dport 500 sport 500 Global (I) QM_IDLE
*Nov  7 23:12:55 Winter: ISAKMP: set new node 734369673 to QM_IDLE
*Nov  7 23:12:55 Winter: ISAKMP:(2458): processing HASH payload. message ID = 734369673
*Nov  7 23:12:55 Winter: ISAKMP:(2458): processing NOTIFY PROPOSAL_NOT_CHOSEN protocol 3
        spi 3927145352, message ID = 734369673, sa = 84F5FF70
*Nov  7 23:12:55 Winter: ISAKMP:(2458): deleting spi 3927145352 message ID = -2109933165
*Nov  7 23:12:55 Winter: ISAKMP:(2458):deleting node -2109933165 error TRUE reason "Delete Larval"
*Nov  7 23:12:55 Winter: ISAKMP:(2458):deleting node 734369673 error FALSE reason "Informational (in) state 1"
*Nov  7 23:12:55 Winter: ISAKMP:(2458):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
*Nov  7 23:12:55 Winter: ISAKMP:(2458):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
*Nov  7 23:13:15 Winter: ISAKMP:(2458):purging node -1653111772
*Nov  7 23:13:15 Winter: ISAKMP:(2458):purging node 457267733
and this is the ACL:
czprab01#sh ip access 110
Extended IP access list 110
    10 deny icmp any any redirect log
    20 deny ip 127.0.0.0 0.255.255.255 any log
    30 deny ip 224.0.0.0 31.255.255.255 any log
    40 deny ip host 0.0.0.0 any log
    50 permit esp host 216.40.52.7 any
    60 permit udp host 216.40.52.7 any eq isakmp
    70 permit gre host 216.40.52.7 any
    80 permit udp host 216.40.52.7 any eq non500-isakmp (16355 matches)
    90 permit esp host 216.40.48.53 any
    100 permit udp host 216.40.48.53 any eq isakmp (256 matches)
    110 permit gre host 216.40.48.53 any
    120 permit udp host 216.40.48.53 any eq non500-isakmp
    130 deny ip any any log (18 matches)
I will appreciate any comment
I am not sure if you resolved this and I am new to replying so forgive if I am doing incorrectly but..
I noticed you did not have the word shared under your tunnel protection statement as this is needed
tunnel protection ipsec profile CHEP shared
Hello
can you try...
Int tun xx
tunnel mode gre multipoint
ip nhrp map multicast 216.40.48.53
ip mtu 1400
ip tcp adjust-mss 1360
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
