Redundancy on WAN link
manojkumard
I have two WAN routers where two different ISP were terminating on the router and both the routers were connected to the Firewall through unmanageable switch as a mediator.
Also, I have two IANA subnet (ex. 1.1.1.0/24 & 2.2.2.0/24), where 1.1.1.1 is configured on Router A & 2.2.2.1 is configured on Router B. On firewall interface1 IP is 1.1.1.2 & interface2 IP is 2.2.2.2.
Issue here is, Since, all both subet are directly connected from firewall to router, where ISP A goes down, only IP subnet on 2.2.2.0/24 is going through ISP B. but, what i required is when ISP A goes down, i need all my traffic need to routed to secondary ISP link including subnet 1.1.1.0/24 traffic.
Required your suggestion....
Hello, Manoj.
To keep both prefixes in case when singl router goes down, you need to run BGP with your ISPs and advertise your prefixes to both of them.
PS: having single firewall servicing single link is not a best practise; it' much better to run 2 firewalls in failover mode (having multiple contexts).
Thanks for your reply....
But if i run BGP also,it wont be effective.. becoz.. We have 2 default gateway (1.1.1.1 & 2.2.2.1) pointing to two different routers... So, if we ru n BGP also, If primary link goes down (1.1.1.1), incoming traffic will come via secondary link(2.2.2.1) but outgoing traffic will fall on primary link(1.1.1.1).... any suggestions...
Hello.
Below is a just a default scenario but you could also incorporate this with PBR
Ip sla 1
Echo-Icmp (dest isp1) (scr wan link to isp1)
freq 5
ip sla schedule 1 start-time now life forever
track 1 rtr 1 reachability
Ip route x.x.x.x x.x.x.x ISP1 200 track 1
Ip route x.x.x.x x.x.x.x ISP2 200
Res
Paul
Kind Regards
Paul
