DMVPN / EIGRP - Layer 3 Switch Behind Router
adamtodd16
Level 3
Level 3
I am currently labbing a DMVPN / EIGRP environment to replace our existing IPsec environment. Our core environment looks like this:
Core Router (2951)
Core Switch (3750)
Spoke Router (2911)
I've set-up the tunnel interface and EIGRP between the Core Router and Spoke and communication is no problem. The issue I am running into is the core switch houses the majority of our VLANS, so the spoke router can reach the core router, but not behind it to the switch.
The Core Router and Switch are connected by an access port with a separate EIGRP config.
Suggestions?
Hello
Have you tried redistributing between the eigrp processes  or apply some static routes?
res
Paul
Kind Regards
Paul
All works great if I add static routers on the hub.
I'm new to using EIGRP. How would I redistribute between the processes?
I simply added:
router eigrp 50
redistribute eigrp 11
All is working now. Is there any caveats I should be aware of?
Hello
Mutual redistribution  can be quite difficult to manage especially when you have multiple exit points attached to different routing processes which can easily  introduce loops in the network( something that we don't want to occur)
But these can be managed by Racls Tagging, metric manipulation etc. to the routes you are advertising/redistributing.
res
Paul
Kind Regards
Paul
