DMVPN - HSRP - EIGRP Issues
adamtodd16
Level 3
Level 3
I'm currently in the process of a mass DMVPN deployment. Right now, we have a single HUB and a few sites are slated to have DUAL SPOKE.
HUB
Cisco 2951
Spoke
R1 - Cisco 2911
R2 - Cisco 2911
HSRP w/ IP SLA Tracking between R1 and R2
I have tunnels on each of the above Spoke Routers pointing to the Tunnel interface at the HUB. Traffic and EIGRP are working as expected on R1.
When R1 is rebooted, R2 takes over the virutal IP and becomes the active HSRP router; however, routes are removed from the HUB and R2 never learns about them / passes traffic.
HUB Config:
interface Tunnel0
 description DMVPN Tunnel
 ip address 172.16.1.1 255.255.255.0
 no ip redirects
 no ip next-hop-self eigrp 50
 no ip split-horizon eigrp 50
 ip nhrp authentication firewall
 ip nhrp map multicast dynamic
 ip nhrp network-id 1
 tunnel source 1.1.1.1
 tunnel mode gre multipoint
 tunnel protection ipsec profile protect-gre
router eigrp 50
 network 10.0.0.0
 network 172.16.0.0
 network 172.16.1.1 0.0.0.0
 network 192.168.0.0
 redistribute eigrp 11
SPOKE R1 Config
interface Tunnel0
 ip address 172.16.1.17 255.255.255.0
 no ip redirects
 ip nhrp map multicast 1.1.1.1
 ip nhrp map 172.16.1.1 1.1.1.1
 ip nhrp nhs 172.16.1.1
 ip virtual-reassembly in
 tunnel source GigabitEthernet0/0
interface GigabitEthernet0/1.17
 description LAN
 encapsulation dot1Q 17
 ip address 10.96.17.253 255.255.255.0
 ip access-group OUTBOUND in
 ip flow ingress
 ip flow egress
 ip nat inside
 standby 0 ip 10.96.17.254
 standby 0 priority 110
 standby 0 preempt
 standby 0 track 1 decrement 20
router eigrp 50
 network 10.96.17.0 0.0.0.255
 network 172.16.1.17 0.0.0.0
 network 192.168.17.0
 redistribute static route-map STATICS
SPOKE R2 Config
interface Tunnel0
 ip address 172.16.1.16 255.255.255.0
 no ip redirects
 description LAN
 ip address 10.96.17.252 255.255.255.0
 ip flow ingress
 ip flow egress
 ip nat inside
 standby 0 preempt
router eigrp 50
 network 172.20.1.16 0.0.0.0
Richard Burts
The biggest issue that I see here is that on R2 there is no network statement in EIGRP to get the routing protocol to run over the tunnel. You need something that might look somewhat like this
 network 172.16.1.16 0.0.0.0
Rick
Rick
Richard Burts
Rick
Rick
Thanks Rick - a good reminder is that sometimes typing 172.20 instead of 172.16 can cause all kinds of pain! :)
Yes sometimes it is those very small details that cause all kinds of pain and sometimes take a fresh pair of eyes to find. Glad I could help. Thank you for using the rating system to mark this question as answered.
Rick
Rick
