DMVPN INTF state
Hi all,
I want to know about the INTF DMVPN state.And I also want to know about this below command:
->>>>>>  ip nhrp nhs x.x.x.x nbma y.y.y.y multicast
My testing for this command is :
R4#sh run int t0
Building configuration...
Current configuration : 220 bytes
interface Tunnel0
ip address 100.0.255.4 255.255.255.0
ip mtu 1400
ip nhrp authentication CISCO
ip nhrp network-id 1
ip nhrp nhs 100.0.255.2 nbma 10.0.26.2 multicast
ip nhrp shortcut
ip tcp adjust-mss 1360
end
R4#show dmvpn
Type:Spoke, NHRP Peers:1,
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb
1 10.0.26.2 100.0.255.2 INTF never S
this tunnel need source and destination mode are multipoint to work
Thanks , This is my requirement . I carelessly forget to do it . After I add tunnel soure and mode gre multipoint ,DMVPN is up .
One more point that I want to know is the usage of this command :
With the using of this , I do not need to write some command such that :
ip nhrp map multicast x.x.x.x
ip nhrp map x.x.x.x y.y.y.y
How it is ?
correct you are right
OR
ip nhrp map multicast x.x.x.x AND ip nhrp map x.x.x.x y.y.y.y
these commands do same you can use any, i prefer second one.
post the full running configs of both the hub and the spoke...
