DMVPN is not coming UP! @secondary router
prabinchand
I am trying to form dmvpn between HEAD-OFFICE (primary and secondary router) & BRANCH but dmvpn is up only with HEAD-OFFICE-PRIMARY router & BRANCH router. NO any dmvpn is formed between HO-SECONDARY router. The config & topology is attached below:
NOTE: no any config it done on ISP SWTICH, it is just a layer 2 switch.
CONFIGURATION:
HEADOFFICE-PRIMARY:
HEAD-OFFICE-PRIMARY(config)#do sh run
Building configuration...
Current configuration : 1756 bytes
! Last configuration change at 11:33:35 UTC Mon Jan 17 2022
version 15.2
hostname HEAD-OFFICE-PRIMARY
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
interface Tunnel1
description ***PRIMARY - TUNNEL****
ip address 50.50.50.1 255.255.255.248
no ip redirects
ip nhrp authentication SECURE
ip nhrp map multicast dynamic
ip nhrp network-id 1
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 123456
interface Tunnel2
description ***SECONDARY -TUNNEL***
ip address 60.60.60.1 255.255.255.248
no ip redirects
ip nhrp authentication SECURE2
ip nhrp network-id 2
tunnel source FastEthernet1/1
tunnel key 456456
interface FastEthernet0/0
description ***PRIMARY ISP***
ip address 1.1.1.1 255.255.255.248
speed auto
duplex auto
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
standby 1 ip 192.168.10.10
standby 1 priority 110
standby 1 preempt
speed auto
duplex auto
interface FastEthernet1/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet1/1
description ***SECONDARY ISP***
ip address 2.2.2.1 255.255.255.248
speed auto
duplex auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
HEADOFFICE-SECONDARY:
HEAD-OFFICE-SECONDAR(config)#do sh run
Current configuration : 1668 bytes
! Last configuration change at 12:25:02 UTC Mon Jan 17 2022
version 15.2
hostname HEAD-OFFICE-SECONDARY
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Tunnel1
ip address 50.50.50.3 255.255.255.248
no ip redirects
tunnel key 123456
interface Tunnel2
ip address 60.60.60.3 255.255.255.248
no ip redirects
tunnel key 456456
ip address 1.1.1.3 255.255.255.248
speed auto
duplex auto
ip address 192.168.10.2 255.255.255.0
standby 1 preempt
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
description ***SEDONDARY - ISP***
ip address 2.2.2.3 255.255.255.248
speed auto
duplex auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
BRANCH:
BRANCH(config)#do sh run
Current configuration : 2170 bytes
version 15.2
hostname BRANCH
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
interface Loopback1
ip address 192.168.100.100 255.255.255.255
interface Tunnel1
ip address 50.50.50.2 255.255.255.248
no ip redirects
ip nhrp map multicast 1.1.1.1
ip nhrp map 50.50.50.1 1.1.1.1
ip nhrp map 50.50.50.3 1.1.1.3
ip nhrp map multicast 1.1.1.3
ip nhrp nhs 50.50.50.1
ip nhrp nhs 1.1.1.1
ip nhrp nhs 1.1.1.3 priority 1
ip nhrp nhs cluster 1 max-connections 1
ip nhrp nhs fallback 2
tunnel key 123456
interface Tunnel2
description ***SECONDARY - TUNNEL ***
ip address 60.60.60.2 255.255.255.248
no ip redirects
ip nhrp map multicast 2.2.2.1
ip nhrp map 60.60.60.1 2.2.2.1
ip nhrp map 60.60.60.3 2.2.2.3
ip nhrp map multicast 2.2.2.3
ip nhrp nhs 60.60.60.1
ip nhrp nhs 2.2.2.1
ip nhrp nhs 2.2.2.3 priority 1
tunnel key 456456
description ***PRIMARY -ISP***
ip address 1.1.1.2 255.255.255.248
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
description ***SECONDARY -ISP***
ip address 2.2.2.2 255.255.255.248
speed auto
duplex auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
at first glance, I would say the NHS mappings on your branch router are wrong. You need to map to the tunnel IP addresses, not the physical interfaces. Make the changes marked in bold:
interface Tunnel1
no ip redirects
--> no ip nhrp nhs 1.1.1.1
--> no ip nhrp nhs 1.1.1.3 priority 1
tunnel key 123456
interface Tunnel2
no ip redirects
--> no ip nhrp nhs 2.2.2.1
--> no ip nhrp nhs 2.2.2.3 priority 1
tunnel key 456456
interface Tunnel1
no ip redirects
tunnel key 123456
interface Tunnel2
no ip redirects
tunnel key 456456
