DMVPN Problem
Mero Cisco
I have the following configuration but I can't ping to tunnel from one spoke router to hub router and vice versa. I have the static ip on HUB fa0/1 interface and dhcp ip on spoke router. Does dhcp plays any role in disfunction of this one.
HUB:
interface Tunnel12
ip address 172.28.18.1 255.255.255.0
no ip redirects
ip mtu 1436
ip nhrp map multicast dynamic
ip nhrp network-id 11386
tunnel source fa0/1
tunnel mode gre multipoint
tunnel key 111386
SPOKE: (dhcp private ip)
interface Tunnel12
ip address 172.28.18.19 255.255.255.0
no ip redirects
ip mtu 1436
ip nhrp map multicast  x.x.x.x
ip nhrp map 172.28.18.1  x.x.x.x
ip nhrp nhs 172.28.18.1
tunnel source FastEthernet0/0
tunnel key 111386
Mero
Jeff Van Houten
Level 5
Level 5
There appear to be a few statements missing. Look at doc id 29240 on Cco. It will guide you to a perfect conclusion.
