DMVPN Router Redundancy with GLBP
Duane Cleary
Folk,
Just looking for a hand,  my challenge is our single point of failure in our  branch offices is the router and we are looking to eliminate this.
Through reading it seems that a dual router configuration, with GLBP might be the best option.
At this point in a LAB i have 2 routers, with single gre tunnels working, and using vlan 1 for the internal corp network.  I have enabled GLBP on vlan1 but it does not seem to be working.
Here is the vlan config
interface Vlan1
description Local LAN Connection
ip address 10.143.250.252 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1380
ip policy route-map clear-df
no autostate
glbp 1 ip 10.143.250.254
glbp 1 preempt
glbp 1 weighting 50
glbp 1 load-balancing weighted
glbp 1 authentication text empire95
Here is the GLBP output that I get from sh glbp br.  This looks exaclty the same on both sides.  I am able to ping the tunnel ip from each of the routers.
Interface   Grp  Fwd Pri State    Address         Active router   Standby router
Vl1         1    -   100 Active   10.143.250.254  local           unknown
Vl1         1    1   -   Active   0007.b400.0101  local           -
D
Marwan ALshawi
Why are you using glbp ?
Are looking for active standby solution ? If yes then you may use HSRP and use routing metrics or administrative distance to align path election over the mgre tunnels wiith the active HSRP
If you are looking for load balancing then glbp might be used but you will face asymmetrical routing issue
Hope this help
