DMVPN Spoke (ISR1921) failing to peer with Hub (C8500)
It looks like there was something up with that specific router, I just applied that same configuration to a newer router (ISR4431) and it came up just fine lol. Thanks again for your help !
12 Replies 12
what if you use the Cisco default transform set (and don't use the one you configured yourself ?
crypto ipsec profile DMVPN-IPSEC-PROFILE
--> no set transform-set DMVPN-IPSEC-TSET
set ikev2-profile DMVPN-IKE-PROFILE
Still does not work after removing TSET on both spoke and hub, unfortunately,
USA-ATL-QTS-CORE2(config)#crypto ipsec profile DMVPN-IPSEC-PROFILE
USA-ATL-QTS-CORE2(ipsec-profile)#no set transform-set DMVPN-IPSEC-TSET
USA-ATL-QTS-CORE2(ipsec-profile)#end
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#show
*Nov 11 17:21:37.764: %SYS-5-CONFIG_I: Configured from console by console
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#clear cry
USA-ATL-QTS-CORE2#clear crypto ik
USA-ATL-QTS-CORE2#clear crypto ikev2 sa
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
USA-ATL-QTS-CORE2#
*Nov 11 17:22:15.517: IKEv2:Received Packet [From X.X.X.X:500/To X.X.X.X:500/VRF i0:f2]
Initiator SPI : 1120EC34C7CE4E0F - Responder SPI : 0000000000000000 Message id: 0
IKEv2 IKE_SA_INIT Exchange REQUEST
Payload contents:
SA KE N VID NOTIFY(NAT_DETECTION_SOURCE_IP) NOTIFY(NAT_DETECTION_DESTINATION_IP)
*Nov 11 17:22:15.517: IKEv2:(SESSION ID = 173,SA ID = 1):Verify SA init message
*Nov 11 17:22:15.517: IKEv2:(SESSION ID = 173,SA ID = 1):Insert SA
*Nov 11 17:22:15.518: IKEv2:Searching Policy with fvrf 2, local address X.X.X.X
*Nov 11 17:22:15.518: IKEv2:Found Policy 'DMVPN-IKE-POLICY'
*Nov 11 17:22:15.518: IKEv2:(SESSION ID = 173,SA ID = 1):Processing IKE_SA_INIT message
*Nov 11 17:22:15.518: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Retrieve configured trustpoint(s)
*Nov 11 17:22:15.518: IKEv2:(SA ID = 1):[PKI -> IKEv2] Retrieved trustpoint(s): 'SLA-TrustPoint' 'TP-self-signed-632393052'
*Nov 11 17:22:15.518: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Get Public Key Hashes of trustpoints
*Nov 11 17:22:15.518: IKEv2:(SA ID = 1):[PKI -> IKEv2] Getting of Public Key Hashes of trustpoints PASSED
*Nov 11 17:22:15.518: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Start PKI Session
*Nov 11 17:22:15.518: IKEv2:(SA ID = 1):[PKI -> IKEv2] Starting of PKI Session PASSED
*Nov 11 17:22:15.518: IKEv2:(SESSION ID = 173,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH public key, DH Group 14
*Nov 11 17:22:15.518: IKEv2:(SESSION ID = 173,SA ID = 1):(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Nov 11 17:22:15.518: IKEv2:(SESSION ID = 173,SA ID = 1):Request queued for computation of DH key
*Nov 11 17:22:15.518: IKEv2:(SESSION ID = 173,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH secret key, DH Group 14
*Nov 11 17:22:15.519: IKEv2:(SESSION ID = 173,SA ID = 1):Request queued for computation of DH secret
*Nov 11 17:22:15.521: IKEv2:(SESSION ID = 173,SA ID = 1):(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Nov 11 17:22:15.521: IKEv2:(SESSION ID = 173,SA ID = 1):(SA ID = 1):[IKEv2 -> Crypto Engine] Calculate SKEYSEED and create rekeyed IKEv2 SA
*Nov 11 17:22:15.521: IKEv2:(SESSION ID = 173,SA ID = 1):(SA ID = 1):[Crypto Engine -> IKEv2] SKEYSEED calculation and creation of rekeyed IKEv2 SA PASSED
*Nov 11 17:22:15.521: IKEv2:IKEv2 responder - no config data to send in IKE_SA_INIT exch
*Nov 11 17:22:15.521: IKEv2:(SESSION ID = 173,SA ID = 1):Generating IKE_SA_INIT message
*Nov 11 17:22:15.521: IKEv2:(SESSION ID = 173,SA ID = 1):IKE Proposal: 1, SPI size: 0 (initial negotiation),
Num. transforms: 4
AES-CBC SHA384 SHA384 DH_GROUP_2048_MODP/Group 14
*Nov 11 17:22:15.521: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Retrieve configured trustpoint(s)
*Nov 11 17:22:15.521: IKEv2:(SA ID = 1):[PKI -> IKEv2] Retrieved trustpoint(s): 'SLA-TrustPoint' 'TP-self-signed-632393052'
*Nov 11 17:22:15.521: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Get Public Key Hashes of trustpoints
*Nov 11 17:22:15.521: IKEv2:(SA ID = 1):[PKI -> IKEv2] Getting of Public Key Hashes of trustpoints PASSED
*Nov 11 17:22:15.521: IKEv2:(SESSION ID = 173,SA ID = 1):Sending Packet [To X.X.X.X :500/From X.X.X.X:500/VRF i0:f2]
Initiator SPI : 1120EC34C7CE4E0F - Responder SPI : 18FD7DF775AE93BE Message id: 0
IKEv2 IKE_SA_INIT Exchange RESPONSE
Payload contents:
SA KE N VID VID VID VID NOTIFY(NAT_DETECTION_SOURCE_IP) NOTIFY(NAT_DETECTION_DESTINATION_IP) CERTREQ NOTIFY(HTTP_CERT_LOOKUP_SUPPORTED)
*Nov 11 17:22:15.522: IKEv2:(SESSION ID = 173,SA ID = 1):Completed SA init exchange
*Nov 11 17:22:15.522: IKEv2:(SESSION ID = 173,SA ID = 1):Starting timer (30 sec) to wait for auth message
*Nov 11 17:22:15.727: IKEv2:(SESSION ID = 173,SA ID = 1):Received Packet [From X.X.X.X :500/To X.X.X.X:500/VRF i0:f2]
Initiator SPI : 1120EC34C7CE4E0F - Responder SPI : 18FD7DF775AE93BE Message id: 1
IKEv2 IKE_AUTH Exchange REQUEST
Payload contents:
USA-ATL-QTS-CORE2#
*Nov 11 17:22:15.728: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):Failed to parse the packet: Failed to decrypt an encrypted payload
USA-ATL-QTS-CORE2#
*Nov 11 17:22:17.565: IKEv2:(SESSION ID = 173,SA ID = 1):Received Packet [From X.X.X.X:500/To X.X.X.X:500/VRF i0:f2]
Payload contents:
*Nov 11 17:22:17.566: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):Failed to parse the packet: Failed to decrypt an encrypted payload
USA-ATL-QTS-CORE2#
*Nov 11 17:22:21.417: IKEv2:(SESSION ID = 173,SA ID = 1):Received Packet [From X.X.X.X:500/To X.X.X.X:500/VRF i0:f2]
Payload contents:
*Nov 11 17:22:21.418: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):Failed to parse the packet: Failed to decrypt an encrypted payload
USA-ATL-QTS-CORE2#
*Nov 11 17:22:28.677: IKEv2:(SESSION ID = 173,SA ID = 1):Received Packet [From X.X.X.X:500/To X.X.X.X:500/VRF i0:f2]
Payload contents:
*Nov 11 17:22:28.678: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):Failed to parse the packet: Failed to decrypt an encrypted payload
USA-ATL-QTS-CORE2#
*Nov 11 17:22:43.601: IKEv2:(SESSION ID = 173,SA ID = 1):Received Packet [From X.X.X.X:500/To X.X.X.X:500/VRF i0:f2]
Payload contents:
*Nov 11 17:22:43.602: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):Failed to parse the packet: Failed to decrypt an encrypted payload
USA-ATL-QTS-CORE2#
*Nov 11 17:22:45.523: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):: Failed to receive the AUTH msg before the timer expired
*Nov 11 17:22:45.523: IKEv2:(SESSION ID = 173,SA ID = 1):Auth exchange failed
*Nov 11 17:22:45.524: IKEv2-ERROR:(SESSION ID = 173,SA ID = 1):: Auth exchange failed
*Nov 11 17:22:45.526: IKEv2:(SESSION ID = 173,SA ID = 1):Abort exchange
*Nov 11 17:22:45.526: IKEv2:(SESSION ID = 173,SA ID = 1):Deleting SA
*Nov 11 17:22:45.526: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Close PKI Session
*Nov 11 17:22:45.526: IKEv2:(SA ID = 1):[PKI -> IKEv2] Closing of PKI Session PASSED
USA-ATL-QTS-CORE2#u all
All possible debugging has been turned off
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 209.10.135.20/500 108.209.101.252/500 FVRF/none IN-NEG
Encr: AES-CBC, keysize: 256, PRF: SHA384, Hash: SHA384, DH Grp:14, Auth sign: Unknown - 0, Auth verify: Unknown - 0
Life/Active Time: 120/0 sec
IPv6 Crypto IKEv2 SA
SPOKE IKE SA:
DMVPN-SPOKE-TEST#show crypto ikev2 sa
1 108.209.101.252/500 209.10.135.20/500 FVRF/FVRF IN-NEG
Encr: AES-CBC, keysize: 256, Hash: SHA384, DH Grp:14, Auth sign: PSK, Auth verify: Unknown - 0
Life/Active Time: 86400/0 sec
post the full running configs of both the hub and the spoke...
at first glance, I think you have to place the EIGRP into the VRF on both the hub and the spoke...
--> address-family ipv4 vrf FRVF autonomous-system
EIGRP works just fine with the current configuration once I remove tunnel protection from the tunnel. So no changes need to be made with that configuration. So it is not a configuration issue with the EIGRP but the IPSec policy I am thinking.
this is going to be trial and error. First, try and change the transport mode (on both routers):
--> crypto ipsec transform-set DMVPN-IPSEC-TSET esp-aes 256 esp-sha256-hmac
mode tunnel
If that doesn't help, change the entire encryption algorithm:
crypto ikev2 proposal DMVPN-IKE-PROPOSAL
encryption aes-cbc-128 aes-cbc-192
integrity sha256 sha512
group 14 15
crypto ipsec transform-set DMVPN-IPSEC-TSET esp-aes 192 esp-sha512-hmac
mode tunnel
No, still no go:
Log from HUB:
Initiator SPI : 895E0752E5F60D27 - Responder SPI : 6EEC1016ECCA629F Message id: 1
*Nov 11 20:13:46.694: IKEv2-ERROR:Address type 1370903749 not supported
*Nov 11 20:13:46.695: IKEv2-ERROR:: A supplied parameter is incorrect
*Nov 11 20:14:32.167: IKEv2-ERROR:(SESSION ID = 245,SA ID = 1):Failed to parse the packet: Failed to decrypt an encrypted payload
USA-ATL-QTS-CORE2#
*Nov 11 20:14:33.249: IKEv2-ERROR:(SESSION ID = 245,SA ID = 1):: Failed to receive the AUTH msg before the timer expired
*Nov 11 20:14:33.249: IKEv2:(SESSION ID = 245,SA ID = 1):Auth exchange failed
*Nov 11 20:14:33.250: IKEv2-ERROR:(SESSION ID = 245,SA ID = 1):: Auth exchange failed
*Nov 11 20:14:33.252: IKEv2:(SESSION ID = 245,SA ID = 1):Abort exchange
*Nov 11 20:14:33.252: IKEv2:(SESSION ID = 245,SA ID = 1):Deleting SA
*Nov 11 20:14:33.252: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Close PKI Session
*Nov 11 20:14:33.252: IKEv2:(SA ID = 1):[PKI -> IKEv2] Closing of PKI Session PASSED
*Nov 11 20:15:01.707: IKEv2-ERROR:Address type 2147505723 not supported
*Nov 11 20:15:01.708: IKEv2-ERROR:Couldn't find matching SA: Detected an invalid IKE SPI
*Nov 11 20:15:01.708: IKEv2:(SESSION ID = 0,SA ID = 0):Received Packet [From X.X.X.X:500/To X.X.X.X:500/VRF i0:f2]
Initiator SPI : D7658ADB17E94E8E - Responder SPI : 57AFA5C20B16C19E Message id: 1
*Nov 11 20:15:01.710: IKEv2-ERROR:Address type 1370903749 not supported
*Nov 11 20:15:01.711: IKEv2-ERROR:: A supplied parameter is incorrect
good to know ! Good idea to replace the router. I think the 1921 is EoL, the replacement is the 4221...
still this issue or solve after change the router ??
The issue was resolved after swapping out 1921 with 4431. Thanks.
