DMVPN SPOKE ISSUE flapping
dnsroot13
Hi Guys
I am having serious  issue on one of the spoke.
there is an adsl connection on spoke and tunnel keep going down .same config on other spokes having adsl connection have no issue .(there are few drops when ping 8.8.8.8 from spoke router sometime)-not sure if due  that having an issue or something else .can you pleae help me to address the issue
below are the logs and spoke config .
sh cry isa sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
94.56.66.60     192.168.15.96   MM_NO_STATE       2060 ACTIVE (deleted)
sh cry isa sa
94.56.66.60     192.168.15.96   MM_KEY_EXCH       2061 ACTIVE
000768: *Nov  5 12:45:56.522: ISAKMP (2076): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
000769: *Nov  5 12:45:56.522: ISAKMP:(2076): phase 1 packet is a duplicate of a previous packet.
000770: *Nov  5 12:45:56.522: ISAKMP:(2076): retransmitting due to retransmit phase 1
000771: *Nov  5 12:45:57.022: ISAKMP:(2076): retransmitting phase 1 MM_KEY_EXCH...
000772: *Nov  5 12:45:57.022: ISAKMP (2076): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
000773: *Nov  5 12:45:57.022: ISAKMP:(2076): retransmitting phase 1 MM_KEY_EXCH
000774: *Nov  5 12:45:57.022: ISAKMP:(2076): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000775: *Nov  5 12:45:57.022: ISAKMP:(2076):Sending an IKE IPv4 Packet.cle
KSA_HO#clear cry isa
KSA_HO#
000776: *Nov  5 12:46:01.350: del_node src 192.168.15.96:4500 dst 94.56.66.60:4500 fvrf 0x0, ivrf 0x0
000777: *Nov  5 12:46:01.350: ISAKMP:(2076):peer does not do paranoid keepalives.
000778: *Nov  5 12:46:01.350: ISAKMP:(2076):deleting SA reason "Death by tree-walk" state (I) MM_KEY_EXCH (peer 94.56.66.60)
000779: *Nov  5 12:46:01.350: ISAKMP:(2076):deleting SA reason "Death by tree-walk" state (I) MM_KEY_EXCH (peer 94.56.66.60)
000780: *Nov  5 12:46:01.350: ISAKMP: Unlocking peer struct 0x88F90CC4 for isadb_mark_sa_deleted(), count 0
000781: *Nov  5 12:46:01.350: ISAKMP: Deleting peer node by peer_reap for 94.56.66.60: 88F90CC4
000782: *Nov  5 12:46:01.350: ISAKMP:(2076):deleting node 1501559703 error FALSE reason "IKE deleted"
000783: *Nov  5 12:46:01.350: ISAKMP:(2076):deleting node -304454932 error FALSE reason "IKE deleted"
000784: *Nov  5 12:46:01.350: ISAKMP:(2076):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
000785: *Nov  5 12:46:01.350: ISAKMP:(2076):Old State = IKE_I_MM5  New State = IKE_DEST_SA
000786: *Nov  5 12:46:06.286: ISAKMP:(0): SA request profile is (NULL)
000787: *Nov  5 12:46:06.286: ISAKMP: Created a peer struct for 94.56.66.60, peer port 500
000788: *Nov  5 12:46:06.286: ISAKMP: New peer created peer = 0x88F90CC4 peer_handle = 0x800001B7
000789: *Nov  5 12:46:06.286: ISAKMP: Locking peer struct 0x88F90CC4, refcount 1 for isakmp_initiator
000790: *Nov  5 12:46:06.286: ISAKMP: local port 500, remote port 500
000791: *Nov  5 12:46:06.286: ISAKMP: set new node 0 to QM_IDLE
000792: *Nov  5 12:46:06.286: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 87F98DE0
000793: *Nov  5 12:46:06.286: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000794: *Nov  5 12:46:06.286: ISAKMP:(0):found peer pre-shared key matching 94.56.66.60
000795: *Nov  5 12:46:06.286: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
000796: *Nov  5 12:46:06.286: ISAKMP:(0): constructed NAT-T vendor-07 ID
000797: *Nov  5 12:46:06.286: ISAKMP:(0): constructed NAT-T vendor-03 ID
000798: *Nov  5 12:46:06.286: ISAKMP:(0): constructed NAT-T vendor-02 ID
000799: *Nov  5 12:46:06.286: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
000800: *Nov  5 12:46:06.286: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
000801: *Nov  5 12:46:06.286: ISAKMP:(0): beginning Main Mode exchange
000802: *Nov  5 12:46:06.286: ISAKMP:(0): sending packet to 94.56.66.60 my_port 500 peer_port 500 (I) MM_NO_STATE
000803: *Nov  5 12:46:06.286: ISAKMP:(0):Sending an IKE IPv4 Packet.
000804: *Nov  5 12:46:06.394: ISAKMP (0): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_NO_STATE
000805: *Nov  5 12:46:06.394: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000806: *Nov  5 12:46:06.394: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_I_MM2
000807: *Nov  5 12:46:06.398: ISAKMP:(0): processing SA payload. message ID = 0
000808: *Nov  5 12:46:06.398: ISAKMP:(0): processing vendor id payload
000809: *Nov  5 12:46:06.398: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
000810: *Nov  5 12:46:06.398: ISAKMP (0): vendor ID is NAT-T RFC 3947
000811: *Nov  5 12:46:06.398: ISAKMP:(0):found peer pre-shared key matching 94.56.66.60
000812: *Nov  5 12:46:06.398: ISAKMP:(0): local preshared key found
000813: *Nov  5 12:46:06.398: ISAKMP : Scanning profiles for xauth ...
000814: *Nov  5 12:46:06.398: ISAKMP:(0):Checking ISAKMP transform 1 against priority 10 policy
000815: *Nov  5 12:46:06.398: ISAKMP:      encryption 3DES-CBC
000816: *Nov  5 12:46:06.398: ISAKMP:      hash SHA
000817: *Nov  5 12:46:06.398: ISAKMP:      default group 2
000818: *Nov  5 12:46:06.398: ISAKMP:      auth pre-share
000819: *Nov  5 12:46:06.398: ISAKMP:      life type in seconds
000820: *Nov  5 12:46:06.398: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
000821: *Nov  5 12:46:06.398: ISAKMP:(0):atts are acceptable. Next payload is 0
000822: *Nov  5 12:46:06.398: ISAKMP:(0):Acceptable atts:actual life: 0
000823: *Nov  5 12:46:06.398: ISAKMP:(0):Acceptable atts:life: 0
000824: *Nov  5 12:46:06.398: ISAKMP:(0):Fill atts in sa vpi_length:4
000825: *Nov  5 12:46:06.398: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
000826: *Nov  5 12:46:06.398: ISAKMP:(0):Returning Actual lifetime: 86400
000827: *Nov  5 12:46:06.398: ISAKMP:(0)::Started lifetime timer: 86400.
000828: *Nov  5 12:46:06.398: ISAKMP:(0): processing vendor id payload
000829: *Nov  5 12:46:06.398: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
000830: *Nov  5 12:46:06.398: ISAKMP (0): vendor ID is NAT-T RFC 3947
000831: *Nov  5 12:46:06.398: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000832: *Nov  5 12:46:06.398: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM2
000833: *Nov  5 12:46:06.398: ISAKMP:(0): sending packet to 94.56.66.60 my_port 500 peer_port 500 (I) MM_SA_SETUP
000834: *Nov  5 12:46:06.398: ISAKMP:(0):Sending an IKE IPv4 Packet.
000835: *Nov  5 12:46:06.398: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000836: *Nov  5 12:46:06.398: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM3
000837: *Nov  5 12:46:06.522: ISAKMP (0): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_SA_SETUP
000838: *Nov  5 12:46:06.526: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000839: *Nov  5 12:46:06.526: ISAKMP:(0):Old State = IKE_I_MM3  New State = IKE_I_MM4
000840: *Nov  5 12:46:06.526: ISAKMP:(0): processing KE payload. message ID = 0
000841: *Nov  5 12:46:06.558: ISAKMP:(0): processing NONCE payload. message ID = 0
000842: *Nov  5 12:46:06.558: ISAKMP:(0):found peer pre-shared key matching 94.56.66.60
000843: *Nov  5 12:46:06.558: ISAKMP:(2077): processing vendor id payload
000844: *Nov  5 12:46:06.558: ISAKMP:(2077): vendor ID is Unity
000845: *Nov  5 12:46:06.558: ISAKMP:(2077): processing vendor id payload
000846: *Nov  5 12:46:06.558: ISAKMP:(2077): vendor ID is DPD
000847: *Nov  5 12:46:06.558: ISAKMP:(2077): processing vendor id payload
000848: *Nov  5 12:46:06.558: ISAKMP:(2077): speaking to another IOS box!
000849: *Nov  5 12:46:06.558: ISAKMP:received payload type 20
000850: *Nov  5 12:46:06.558: ISAKMP (2077): NAT found, both nodes inside NAT
000851: *Nov  5 12:46:06.558: ISAKMP:received payload type 20
000852: *Nov  5 12:46:06.558: ISAKMP (2077): My hash no match -  this node inside NAT
000853: *Nov  5 12:46:06.558: ISAKMP:(2077):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000854: *Nov  5 12:46:06.558: ISAKMP:(2077):Old State = IKE_I_MM4  New State = IKE_I_MM4
000855: *Nov  5 12:46:06.558: ISAKMP:(2077):Send initial contact
000856: *Nov  5 12:46:06.562: ISAKMP:(2077):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
000857: *Nov  5 12:46:06.562: ISAKMP (2077): ID payload
        next-payload : 8
        type         : 1
        address      : 192.168.15.96
        protocol     : 17
        port         : 0
        length       : 12
000858: *Nov  5 12:46:06.562: ISAKMP:(2077):Total payload length: 12
000859: *Nov  5 12:46:06.562: ISAKMP:(2077): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000860: *Nov  5 12:46:06.562: ISAKMP:(2077):Sending an IKE IPv4 Packet.
000861: *Nov  5 12:46:06.562: ISAKMP:(2077):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000862: *Nov  5 12:46:06.562: ISAKMP:(2077):Old State = IKE_I_MM4  New State = IKE_I_MM5
000863: *Nov  5 12:46:16.522: ISAKMP (2077): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
000864: *Nov  5 12:46:16.522: ISAKMP:(2077): phase 1 packet is a duplicate of a previous packet.
000865: *Nov  5 12:46:16.522: ISAKMP:(2077): retransmitting due to retransmit phase 1
000866: *Nov  5 12:46:17.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH...
000867: *Nov  5 12:46:17.022: ISAKMP (2077): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
000868: *Nov  5 12:46:17.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH
000869: *Nov  5 12:46:17.022: ISAKMP:(2077): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000870: *Nov  5 12:46:17.022: ISAKMP:(2077):Sending an IKE IPv4 Packet.
000871: *Nov  5 12:46:26.522: ISAKMP (2077): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
000872: *Nov  5 12:46:26.522: ISAKMP:(2077): phase 1 packet is a duplicate of a previous packet.
000873: *Nov  5 12:46:26.522: ISAKMP:(2077): retransmitting due to retransmit phase 1
000874: *Nov  5 12:46:27.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH...
000875: *Nov  5 12:46:27.022: ISAKMP (2077): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
000876: *Nov  5 12:46:27.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH
000877: *Nov  5 12:46:27.022: ISAKMP:(2077): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000878: *Nov  5 12:46:27.022: ISAKMP:(2077):Sending an IKE IPv4 Packet.
000879: *Nov  5 12:46:36.286: ISAKMP: set new node 0 to QM_IDLE
000880: *Nov  5 12:46:36.286: ISAKMP:(2077):SA is still budding. Attached new ipsec request to it. (local 192.168.15.96, remote 94.56.66.60)
000881: *Nov  5 12:46:36.286: ISAKMP: Error while processing SA request: Failed to initialize SA
000882: *Nov  5 12:46:36.286: ISAKMP: Error while processing KMI message 0, error 2.
000883: *Nov  5 12:46:36.522: ISAKMP (2077): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
000884: *Nov  5 12:46:36.522: ISAKMP:(2077): phase 1 packet is a duplicate of a previous packet.
000885: *Nov  5 12:46:36.522: ISAKMP:(2077): retransmitting due to retransmit phase 1
000886: *Nov  5 12:46:37.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH...
000887: *Nov  5 12:46:37.022: ISAKMP (2077): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
000888: *Nov  5 12:46:37.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH
000889: *Nov  5 12:46:37.022: ISAKMP:(2077): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000890: *Nov  5 12:46:37.022: ISAKMP:(2077):Sending an IKE IPv4 Packet.
000891: *Nov  5 12:46:46.522: ISAKMP (2077): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
000892: *Nov  5 12:46:46.522: ISAKMP:(2077): phase 1 packet is a duplicate of a previous packet.
000893: *Nov  5 12:46:46.522: ISAKMP:(2077): retransmitting due to retransmit phase 1
000894: *Nov  5 12:46:47.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH...
000895: *Nov  5 12:46:47.022: ISAKMP (2077): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
000896: *Nov  5 12:46:47.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH
000897: *Nov  5 12:46:47.022: ISAKMP:(2077): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000898: *Nov  5 12:46:47.022: ISAKMP:(2077):Sending an IKE IPv4 Packet.
000899: *Nov  5 12:46:51.350: ISAKMP:(2076):purging node 1501559703
000900: *Nov  5 12:46:51.350: ISAKMP:(2076):purging node -304454932
000901: *Nov  5 12:46:56.522: ISAKMP (2077): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
000902: *Nov  5 12:46:56.522: ISAKMP:(2077): phase 1 packet is a duplicate of a previous packet.
000903: *Nov  5 12:46:56.522: ISAKMP:(2077): retransmitting due to retransmit phase 1
000904: *Nov  5 12:46:57.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH...
000905: *Nov  5 12:46:57.022: ISAKMP (2077): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
000906: *Nov  5 12:46:57.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH
000907: *Nov  5 12:46:57.022: ISAKMP:(2077): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000908: *Nov  5 12:46:57.022: ISAKMP:(2077):Sending an IKE IPv4 Packet.
000909: *Nov  5 12:47:01.350: ISAKMP:(2076):purging SA., sa=86CA5534, delme=86CA5534
000910: *Nov  5 12:47:06.286: ISAKMP: set new node 0 to QM_IDLE
000911: *Nov  5 12:47:06.286: ISAKMP:(2077):SA is still budding. Attached new ipsec request to it. (local 192.168.15.96, remote 94.56.66.60)
000912: *Nov  5 12:47:06.286: ISAKMP: Error while processing SA request: Failed to initialize SA
000913: *Nov  5 12:47:06.286: ISAKMP: Error while processing KMI message 0, error 2.
000914: *Nov  5 12:47:07.022: ISAKMP:(2077): retransmitting phase 1 MM_KEY_EXCH...
000915: *Nov  5 12:47:07.022: ISAKMP:(2077):peer does not do paranoid keepalives.
000916: *Nov  5 12:47:07.022: ISAKMP:(2077):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 94.56.66.60)
000917: *Nov  5 12:47:07.022: ISAKMP:(2077):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 94.56.66.60)
000918: *Nov  5 12:47:07.022: ISAKMP: Unlocking peer struct 0x88F90CC4 for isadb_mark_sa_deleted(), count 0
000919: *Nov  5 12:47:07.022: ISAKMP: Deleting peer node by peer_reap for 94.56.66.60: 88F90CC4
000920: *Nov  5 12:47:07.022: ISAKMP:(2077):deleting node 1354135933 error FALSE reason "IKE deleted"
000921: *Nov  5 12:47:07.022: ISAKMP:(2077):deleting node -517948856 error FALSE reason "IKE deleted"
000922: *Nov  5 12:47:07.022: ISAKMP:(2077):deleting node -1659841532 error FALSE reason "IKE deleted"
000923: *Nov  5 12:47:07.022: ISAKMP:(2077):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
000924: *Nov  5 12:47:07.022: ISAKMP:(2077):Old State = IKE_I_MM5  New State = IKE_DEST_SA
000925: *Nov  5 12:47:36.286: ISAKMP:(0): SA request profile is (NULL)
000926: *Nov  5 12:47:36.286: ISAKMP: Created a peer struct for 94.56.66.60, peer port 500
000927: *Nov  5 12:47:36.286: ISAKMP: New peer created peer = 0x88F90CC4 peer_handle = 0x80000124
000928: *Nov  5 12:47:36.286: ISAKMP: Locking peer struct 0x88F90CC4, refcount 1 for isakmp_initiator
000929: *Nov  5 12:47:36.286: ISAKMP: local port 500, remote port 500
000930: *Nov  5 12:47:36.286: ISAKMP: set new node 0 to QM_IDLE
000931: *Nov  5 12:47:36.286: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 86CA5534
000932: *Nov  5 12:47:36.286: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000933: *Nov  5 12:47:36.286: ISAKMP:(0):found peer pre-shared key matching 94.56.66.60
000934: *Nov  5 12:47:36.286: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
000935: *Nov  5 12:47:36.286: ISAKMP:(0): constructed NAT-T vendor-07 ID
000936: *Nov  5 12:47:36.286: ISAKMP:(0): constructed NAT-T vendor-03 ID
000937: *Nov  5 12:47:36.286: ISAKMP:(0): constructed NAT-T vendor-02 ID
000938: *Nov  5 12:47:36.286: ISAKMP:(0):Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
000939: *Nov  5 12:47:36.286: ISAKMP:(0):Old State = IKE_READY  New State = IKE_I_MM1
000940: *Nov  5 12:47:36.286: ISAKMP:(0): beginning Main Mode exchange
000941: *Nov  5 12:47:36.286: ISAKMP:(0): sending packet to 94.56.66.60 my_port 500 peer_port 500 (I) MM_NO_STATE
000942: *Nov  5 12:47:36.286: ISAKMP:(0):Sending an IKE IPv4 Packet.
000943: *Nov  5 12:47:36.398: ISAKMP (0): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_NO_STATE
000944: *Nov  5 12:47:36.398: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000945: *Nov  5 12:47:36.398: ISAKMP:(0):Old State = IKE_I_MM1  New State = IKE_I_MM2
000946: *Nov  5 12:47:36.398: ISAKMP:(0): processing SA payload. message ID = 0
000947: *Nov  5 12:47:36.398: ISAKMP:(0): processing vendor id payload
000948: *Nov  5 12:47:36.398: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
000949: *Nov  5 12:47:36.398: ISAKMP (0): vendor ID is NAT-T RFC 3947
000950: *Nov  5 12:47:36.398: ISAKMP:(0):found peer pre-shared key matching 94.56.66.60
000951: *Nov  5 12:47:36.398: ISAKMP:(0): local preshared key found
000952: *Nov  5 12:47:36.398: ISAKMP : Scanning profiles for xauth ...
000953: *Nov  5 12:47:36.398: ISAKMP:(0):Checking ISAKMP transform 1 against priority 10 policy
000954: *Nov  5 12:47:36.398: ISAKMP:      encryption 3DES-CBC
000955: *Nov  5 12:47:36.398: ISAKMP:      hash SHA
000956: *Nov  5 12:47:36.398: ISAKMP:      default group 2
000957: *Nov  5 12:47:36.398: ISAKMP:      auth pre-share
000958: *Nov  5 12:47:36.398: ISAKMP:      life type in seconds
000959: *Nov  5 12:47:36.398: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
000960: *Nov  5 12:47:36.398: ISAKMP:(0):atts are acceptable. Next payload is 0
000961: *Nov  5 12:47:36.398: ISAKMP:(0):Acceptable atts:actual life: 0
000962: *Nov  5 12:47:36.398: ISAKMP:(0):Acceptable atts:life: 0
000963: *Nov  5 12:47:36.398: ISAKMP:(0):Fill atts in sa vpi_length:4
000964: *Nov  5 12:47:36.398: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
000965: *Nov  5 12:47:36.398: ISAKMP:(0):Returning Actual lifetime: 86400
000966: *Nov  5 12:47:36.398: ISAKMP:(0)::Started lifetime timer: 86400.
000967: *Nov  5 12:47:36.398: ISAKMP:(0): processing vendor id payload
000968: *Nov  5 12:47:36.398: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
000969: *Nov  5 12:47:36.398: ISAKMP (0): vendor ID is NAT-T RFC 3947
000970: *Nov  5 12:47:36.398: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000971: *Nov  5 12:47:36.398: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM2
000972: *Nov  5 12:47:36.402: ISAKMP:(0): sending packet to 94.56.66.60 my_port 500 peer_port 500 (I) MM_SA_SETUP
000973: *Nov  5 12:47:36.402: ISAKMP:(0):Sending an IKE IPv4 Packet.
000974: *Nov  5 12:47:36.402: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000975: *Nov  5 12:47:36.402: ISAKMP:(0):Old State = IKE_I_MM2  New State = IKE_I_MM3
000976: *Nov  5 12:47:36.526: ISAKMP (0): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_SA_SETUP
000977: *Nov  5 12:47:36.526: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000978: *Nov  5 12:47:36.526: ISAKMP:(0):Old State = IKE_I_MM3  New State = IKE_I_MM4
000979: *Nov  5 12:47:36.530: ISAKMP:(0): processing KE payload. message ID = 0
000980: *Nov  5 12:47:36.562: ISAKMP:(0): processing NONCE payload. message ID = 0
000981: *Nov  5 12:47:36.562: ISAKMP:(0):found peer pre-shared key matching 94.56.66.60
000982: *Nov  5 12:47:36.562: ISAKMP:(2078): processing vendor id payload
000983: *Nov  5 12:47:36.562: ISAKMP:(2078): vendor ID is Unity
000984: *Nov  5 12:47:36.562: ISAKMP:(2078): processing vendor id payload
000985: *Nov  5 12:47:36.562: ISAKMP:(2078): vendor ID is DPD
000986: *Nov  5 12:47:36.562: ISAKMP:(2078): processing vendor id payload
000987: *Nov  5 12:47:36.562: ISAKMP:(2078): speaking to another IOS box!
000988: *Nov  5 12:47:36.562: ISAKMP:received payload type 20
000989: *Nov  5 12:47:36.562: ISAKMP (2078): NAT found, both nodes inside NAT
000990: *Nov  5 12:47:36.562: ISAKMP:received payload type 20
000991: *Nov  5 12:47:36.562: ISAKMP (2078): My hash no match -  this node inside NAT
000992: *Nov  5 12:47:36.562: ISAKMP:(2078):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000993: *Nov  5 12:47:36.562: ISAKMP:(2078):Old State = IKE_I_MM4  New State = IKE_I_MM4
000994: *Nov  5 12:47:36.562: ISAKMP:(2078):Send initial contact
000995: *Nov  5 12:47:36.562: ISAKMP:(2078):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
000996: *Nov  5 12:47:36.562: ISAKMP (2078): ID payload
        next-payload : 8
        type         : 1
        protocol     : 17
        port         : 0
        length       : 12
000997: *Nov  5 12:47:36.562: ISAKMP:(2078):Total payload length: 12
000998: *Nov  5 12:47:36.562: ISAKMP:(2078): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
000999: *Nov  5 12:47:36.562: ISAKMP:(2078):Sending an IKE IPv4 Packet.
001000: *Nov  5 12:47:36.566: ISAKMP:(2078):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
001001: *Nov  5 12:47:36.566: ISAKMP:(2078):Old State = IKE_I_MM4  New State = IKE_I_MM5
001002: *Nov  5 12:47:46.526: ISAKMP (2078): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
001003: *Nov  5 12:47:46.526: ISAKMP:(2078): phase 1 packet is a duplicate of a previous packet.
001004: *Nov  5 12:47:46.526: ISAKMP:(2078): retransmitting due to retransmit phase 1
001005: *Nov  5 12:47:47.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH...
001006: *Nov  5 12:47:47.026: ISAKMP (2078): incrementing error counter on sa, attempt 1 of 5: retransmit phase 1
001007: *Nov  5 12:47:47.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH
001008: *Nov  5 12:47:47.026: ISAKMP:(2078): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
001009: *Nov  5 12:47:47.026: ISAKMP:(2078):Sending an IKE IPv4 Packet.
001010: *Nov  5 12:47:56.526: ISAKMP (2078): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
001011: *Nov  5 12:47:56.526: ISAKMP:(2078): phase 1 packet is a duplicate of a previous packet.
001012: *Nov  5 12:47:56.526: ISAKMP:(2078): retransmitting due to retransmit phase 1
001013: *Nov  5 12:47:57.022: ISAKMP:(2077):purging node 1354135933
001014: *Nov  5 12:47:57.022: ISAKMP:(2077):purging node -517948856
001015: *Nov  5 12:47:57.022: ISAKMP:(2077):purging node -1659841532
001016: *Nov  5 12:47:57.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH...
001017: *Nov  5 12:47:57.026: ISAKMP (2078): incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
001018: *Nov  5 12:47:57.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH
001019: *Nov  5 12:47:57.026: ISAKMP:(2078): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
001020: *Nov  5 12:47:57.026: ISAKMP:(2078):Sending an IKE IPv4 Packet.
001021: *Nov  5 12:48:06.286: ISAKMP: set new node 0 to QM_IDLE
001022: *Nov  5 12:48:06.286: ISAKMP:(2078):SA is still budding. Attached new ipsec request to it. (local 192.168.15.96, remote 94.56.66.60)
001023: *Nov  5 12:48:06.286: ISAKMP: Error while processing SA request: Failed to initialize SA
001024: *Nov  5 12:48:06.286: ISAKMP: Error while processing KMI message 0, error 2.
001025: *Nov  5 12:48:06.526: ISAKMP (2078): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
001026: *Nov  5 12:48:06.526: ISAKMP:(2078): phase 1 packet is a duplicate of a previous packet.
001027: *Nov  5 12:48:06.526: ISAKMP:(2078): retransmitting due to retransmit phase 1
001028: *Nov  5 12:48:07.022: ISAKMP:(2077):purging SA., sa=87F98DE0, delme=87F98DE0
001029: *Nov  5 12:48:07.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH...
001030: *Nov  5 12:48:07.026: ISAKMP (2078): incrementing error counter on sa, attempt 3 of 5: retransmit phase 1
001031: *Nov  5 12:48:07.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH
001032: *Nov  5 12:48:07.026: ISAKMP:(2078): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
001033: *Nov  5 12:48:07.026: ISAKMP:(2078):Sending an IKE IPv4 Packet.
001034: *Nov  5 12:48:16.526: ISAKMP (2078): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
001035: *Nov  5 12:48:16.526: ISAKMP:(2078): phase 1 packet is a duplicate of a previous packet.
001036: *Nov  5 12:48:16.526: ISAKMP:(2078): retransmitting due to retransmit phase 1
001037: *Nov  5 12:48:17.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH...
001038: *Nov  5 12:48:17.026: ISAKMP (2078): incrementing error counter on sa, attempt 4 of 5: retransmit phase 1
001039: *Nov  5 12:48:17.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH
001040: *Nov  5 12:48:17.026: ISAKMP:(2078): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
001041: *Nov  5 12:48:17.026: ISAKMP:(2078):Sending an IKE IPv4 Packet.
001042: *Nov  5 12:48:26.526: ISAKMP (2078): received packet from 94.56.66.60 dport 500 sport 500 Global (I) MM_KEY_EXCH
001043: *Nov  5 12:48:26.526: ISAKMP:(2078): phase 1 packet is a duplicate of a previous packet.
001044: *Nov  5 12:48:26.526: ISAKMP:(2078): retransmitting due to retransmit phase 1
001045: *Nov  5 12:48:27.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH...
001046: *Nov  5 12:48:27.026: ISAKMP (2078): incrementing error counter on sa, attempt 5 of 5: retransmit phase 1
001047: *Nov  5 12:48:27.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH
001048: *Nov  5 12:48:27.026: ISAKMP:(2078): sending packet to 94.56.66.60 my_port 4500 peer_port 4500 (I) MM_KEY_EXCH
001049: *Nov  5 12:48:27.026: ISAKMP:(2078):Sending an IKE IPv4 Packet.
001050: *Nov  5 12:48:36.286: ISAKMP: set new node 0 to QM_IDLE
001051: *Nov  5 12:48:36.286: ISAKMP:(2078):SA is still budding. Attached new ipsec request to it. (local 192.168.15.96, remote 94.56.66.60)
001052: *Nov  5 12:48:36.286: ISAKMP: Error while processing SA request: Failed to initialize SA
001053: *Nov  5 12:48:36.286: ISAKMP: Error while processing KMI message 0, error 2.
001054: *Nov  5 12:48:37.026: ISAKMP:(2078): retransmitting phase 1 MM_KEY_EXCH...
001055: *Nov  5 12:48:37.026: ISAKMP:(2078):peer does not do paranoid keepalives.
001056: *Nov  5 12:48:37.026: ISAKMP:(2078):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 94.56.66.60)
001057: *Nov  5 12:48:37.026: ISAKMP:(2078):deleting SA reason "Death by retransmission P1" state (I) MM_KEY_EXCH (peer 94.56.66.60)
001058: *Nov  5 12:48:37.026: ISAKMP: Unlocking peer struct 0x88F90CC4 for isadb_mark_sa_deleted(), count 0
001059: *Nov  5 12:48:37.026: ISAKMP: Deleting peer node by peer_reap for 94.56.66.60: 88F90CC4
001060: *Nov  5 12:48:37.026: ISAKMP:(2078):deleting node -2010197579 error FALSE reason "IKE deleted"
001061: *Nov  5 12:48:37.026: ISAKMP:(2078):deleting node -2000843173 error FALSE reason "IKE deleted"
001062: *Nov  5 12:48:37.026: ISAKMP:(2078):deleting node 1131329234 error FALSE reason "IKE deleted"
001063: *Nov  5 12:48:37.026: ISAKMP:(2078):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
001064: *Nov  5 12:48:37.026: ISAKMP:(2078):Old State = IKE_I_MM5  New State = IKE_DEST_SA
spoke config:(KEY and everything is matched )
IOS is -Uptime is 23 hours, 1 minute
System returned to ROM by reload at 13:19:19 UTC Wed Nov 4 2015
System image file is "flash:c880data-universalk9-mz.152-3.T.bin"
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxx address 0.0.0.0
crypto isakmp keepalive 60 3
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
crypto ipsec profile dmvpn
set transform-set 3des-sha
bba-group pppoe global
interface Tunnel22
ip address 10.10.1.77 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication xxxxx
ip nhrp map 10.10.1.1 94.56.66.60
ip nhrp map multicast 94.56.66.60
ip nhrp network-id 12
ip nhrp holdtime 60
ip nhrp nhs 10.10.1.1
ip ospf network broadcast
ip ospf priority 0
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 12
tunnel protection ipsec profile dmvpn shared
interface FastEthernet0
description +++LAN Ports+++
switchport access vlan 20
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport mode trunk
no ip address
interface FastEthernet4
description +++WAN Interface++++
ip address 192.168.15.96 255.255.255.0
ip helper-address 172.21.77.100
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan10
no ip address
ip nat inside
interface Vlan20
description +++LAN Layer 3 Address+++
ip address 172.21.77.1 255.255.255.0
ip nat inside
interface Dialer1
no ip address
router ospf 1
router-id 172.21.77.1
network 10.10.1.0 0.0.0.255 area 1
network 172.21.77.0 0.0.0.255 area 1
no ip forward-protocol nd
ip http server
ip http access-class 1
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 192.168.15.7
ip route 172.21.62.0 255.255.255.0 172.21.77.100
ip route 192.168.15.0 255.255.255.0 192.168.15.7
access-list 1 permit 172.21.77.0 0.0.0.255
access-list 1 permit 172.21.62.0 0.0.0.255
access-list 1 permit 192.168.18.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
7 Replies 7
Vahid Tavajjohi
im not sure, but add this:
     mode transport
if its help
Hi Vahid,
IN other spokes which are working fine now its configurd as tunnel mode only
 mode tunnel
I will also check HUB side debug .
Hello Guys
Sorry for the late reply.after upgrading the IOS its stable now .thanks for the inputs
You can use transport mode if all nodes have a public IPv4 address.  Tunnel mode works weather you have a public IP address or not on the outside.  As long as all nodes are configured the same it is fine to be using tunnel mode.
Is the flapping happening at regular repeating intervals?  if so, reasons I have seen for this happening are:
* Two spokes have the same IP address on their Tunnel interfaces (especially if there are two spokes flapping ...).
* Redistributing the "outside" addresses used for the internal in the interior routing protocol
* IOS Bug.  Try comparing the IOS version of a working spoke with one that doesn't work.  If they are different, try using the same IOS version as the spoke that works.
If the flapping is not occurring at regular repeating intervals (aka the tunnel actually works for a while and then breaks) then it is more likely to be a circuit issue.
It looks to me like the hub is not happy with this spoke, as there hub keeps retransmitting a packet.  We would need a debug from the hub as well.  However I bet one of the three things I have given above is the issue.
Hi P.dath The issue is, if the internet links (wan interface) if i shut down and no shut again ,the tunnel will take around 30 mins to comes up else need to reload the router . going to upgrade the IOS as well as there are bugs involved in nearby images.
CSCtx90299
Symptoms: The DMVPN IPsec sessions might get torn down and unable to re- establish themselves after experiencing link-flap events.
Conditions: In a scaled DMVPN environment, when physical-port link-state up/down events happen, there will be stormed IPSec events to tear down and/or re-negotiate the sessions; it might run into a bad state that it cannot establish new sessions. Hence, when those active sessions expire (by time period or volume based), it can no longer be re-created. After some period of time, no more active session remains on the router.
Workaround: Reload the router.
HUB side debug will do after IOS upgrade
Does your WAN interface have a dynamic IP address by chance?  If it does, you'll need to add the below.  Note it wont take effect with the current NHRP registration, but the next NHRP registration (you need to wait for the existing NHRP registration to time out so that the next one gets registered with the no-unique flag).
interface Tunnel 22
  ip nhrp registration no-unique
I see lots of 'peer does not do paranoid keepalives', however you have keepalives configured in your spoke configuration.  Make sure you have keepalives configured on the hub as well.  Otherwise you could simply be having trouble with spi mis-matches on the hub side.
If it is neither of those two issues I vote on an IOS bug.  If could be those issues being compounded by an IOS bug.  Try going to the next "gold star" release.  Especially try making sure you hub is on a good gold star release.
Philip D'Ath
Need the same debug from the head end to see what it is saying,
