DMVPN using 4g with dynamic public IP address
AdamDownie12
We have a medium sized DMVPN network that is working fine in Phase 3.
We have a new site that is using 4g as its primary connection. Every 12 hours the public ip address of this 4g connection changes causing the tunnel to drop.
By adding this command on the spoke the tunnel re-connects after about 5 minutes:
ip nhrp registration no-unique
This is not really ideal and wondering if anyone has an understanding of how this can be made better.
Manually executing clear ip nhrp also fixes the problem but again not ideal.
Using a Cisco 881 running 15.4 for this spoke.
Any ideas or suggests?
Adam
8 Replies 8
you might want to try and set the 'ip nhrp registration timeout' on the spoke tunnel to the lowest value possible...
Can you post the configuration of your 881 ?
Thanks for the suggestion. I just tried that and it did not seem to make any difference. Looks as tho connectivity drops for around 30 minutes. Whats odd is that it does not seem to be off for a consistent amount of time. The router loses internet access for about 20 seconds when the public IP changes. Worth highlighting the public IP address is assigned to a device in front of our router and we receive an NAT'd ip.
Tunnel config:
interface Tunnel1
ip address INTERNAL IP
no ip redirects
ip mtu 1400
ip flow monitor NTA input
ip flow monitor NTA output
ip nhrp authentication EXAMPLE
ip nhrp map multicast PUBLIC IP
ip nhrp map INTERNAL IP PUBLIC IP
ip nhrp network-id 1
ip nhrp holdtime 30
ip nhrp nhs HUB IP
ip nhrp registration timeout 10
ip tcp adjust-mss 1360
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 100
tunnel protection ipsec profile EXAMPLE shared
Adam
I have a feeling the problem is related to the 4G. Can you post the full configuration of your router ?
Hi All,
I am trying to build a DMVPN tunnel in a Cisco 892 router connected to a 4g router. So far from the cisco router I can ping Hub public IP address, but the reverse is not working. I also enabled port forwarding in 4g router , but not sure if it is adding any value. The tunnel configs looks like below. Please let me know if I am missing anything or need any details.
interface Tunnel1
description Tunnel
bandwidth 10000
ip address z.z.z.z 255.255.255.0  //Z denotes Tunnel Ip address
no ip redirects
ip mtu 1400
ip pim sparse-dense-mode
ip nat outside
ip nhrp authentication cisco
ip nhrp map multicast x.x.x.x   //X denotes Public Ip address of Hub
ip nhrp map y.y.y.y x.x.x.x        //Y denotes Hub's tunnel Ip address
ip nhrp network-id 1000
ip nhrp holdtime 300
ip nhrp nhs y.y.y.y
ip nhrp shortcut
ip nhrp redirect
ip virtual-reassembly in
load-interval 30
delay 1000
tunnel source GigabitEthernet8
end
the spoke tunnel config looks ok. Post the config of the hub as well. Which routing (protocol) do you have configured ?
I think the problem is in Natting. I tried to debug and found lot of things
related to Nat. I l post the same in a while. When we have to do Natting
outside the device ,anyone can tell me how to do in 4 g router?
post the full confg of the 4G router as well as the 892 router (sh run). The tunnel is not used as NAT outside, you need to put the NAT outside on the ISP facing interface that has the public IP address...
Larry Sullivan
Level 3
Level 3
Try contacting the provider and asking them to make the IP static.
