DMVPN with 3 hubs failover
ittechk4u1
Level 4
Level 4
Are anyone have sample config with 3 hubs with fail over .
Currently i am using dual hub and it working perfectly.
Spoke to Spoke communication is not required.
I am trying to achieve failover between the 3 Hubs. All the 3 Hubs will have separate Public IPs and all three HUBs are connected vai a VLAN.
Here are my sample config:
HUB1:
interface Tunnel1
bandwidth 80000
ip address 172.31.198.4 255.255.255.0
no ip redirects
ip nhrp authentication DMVPN172
ip nhrp map multicast dynamic
ip nhrp network-id 4
ip nhrp holdtime 300
ip tcp adjust-mss 1360
delay 1000
tunnel source IP1.IP1.IP1.IP1
tunnel mode gre multipoint
tunnel key 4
tunnel protection ipsec profile DMVPN
HUB2:
interface Tunnel1
bandwidth 80000
ip address 172.31.198.5 255.255.255.0
no ip redirects
ip nhrp map 172.31.198.4 IP1.IP1.IP1.IP1
ip nhrp map multicast IP1.IP1.IP1.IP1
ip nhrp nhs 172.31.198.4
delay 1500
tunnel source IP2.IP2.IP2.IP2
tunnel key 4
HUB3:
what should be the config for HUB3 ?
Thanks in advance
5 Replies 5
EDIT: you can use 1 tunnels on the spoke, map it to all three hubs, and use OSPF priority on the hubs. Which routing protocol(s) are you using ?
HI Georg,
Thank you.
I am using single cloud with three HUBs.
HUb1 and HUB2 are active....and working normally. Now i want to add HUB3 in this topology/in same cloud.
What should be the config on HUB3 so that failover works correctly.
here is the config. On the spoke, make sure you add a mapping for the third hub:
HUB_3
interface Tunnel1
bandwidth 80000
ip address 172.31.198.6 255.255.255.0
no ip redirects
ip mtu 1400
delay 2000
tunnel source IP3
tunnel key 4
SPOKE
interface Tunnel1
ip address 172.31.198.7 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 172.31.198.5 IP2
ip nhrp map 172.31.198.6 IP3
ip nhrp nhs 172.31.198.5
ip nhrp nhs 172.31.198.6
tunnel source IPx
tunnel key 4
after this setup i have an issue about HUB priority in Spoke:
my config on spoke:
Spoke:
interface Tunnel1
bandwidth 20000
ip address 172.31.198.51 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 171.31.198.4 IP1.IP1.IP1.IP1
ip nhrp map 172.31.198.5 IP2.IP2.IP2.IP2
ip nhrp map multicast IP2.IP2.IP2.IP2
ip nhrp map 172.31.198.27 IP3.IP3.IP3.IP3
ip nhrp map multicast IP3.IP3.IP3.IP3
ip nhrp nhs 171.31.198.4 priority 2 cluster 4
ip nhrp nhs 171.31.198.5 priority 1 cluster 4
ip nhrp nhs 171.31.198.27 priority 3 cluster 4
ip nhrp nhs cluster 4 max-connections 3
ip nhrp server-only
tunnel source GigabitEthernet0/0/0
tunnel key 4
tunnel vrf ISP1
HUB "171.31.198.4 " has the highest priority in cluster but still all traffic(Default route ) is going over HUB2"171.31.198.5 "  why  ?
priority 1 is higher than priority 2, and 3 is lower than 2. Change the priorities accordingly. Also, the IP addresses start with 171, shouldn't that be 172 ?
ip nhrp nhs 171.31.198.4 priority 2 cluster 4 --> middle
ip nhrp nhs 171.31.198.5 priority 1 cluster 4 --> highest
ip nhrp nhs 171.31.198.27 priority 3 cluster  --> lowest
