Issue with Router on a stick Configuration
Shruti3482
I have connected a modem on switch port 23 and below config is the config on router subinterface and switch port.
This is not working. I can't ping the next hop x.x.x.97. This was working when modem was connected directly to the router.
Any suggestions?
ROUTER
interface GigabitEthernet0/0.110
encapsulation dot1Q 110
vrf forwarding IWAN-PUBLIC
ip address x.x.x.108 255.255.255.240
SWITCH
interface FastEthernet0/23
switchport access vlan 110
switchport mode access
14 Replies 14
Mark Malone
Is the modem is the front facing device with the WAN IP address to get out to the internet ?
It should be connected to the router not the switch , why are you connecting it to the switch ?
the modem wold have to understand how to route back if its connected somewhere else , but if its a modem for the internet it should be connected to the router
good example of RnS
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
Yes modem is a front facing device with WAN IP. There is no free port on the router. Hence, router on a stick.
Router is a CISCO1921/K9 with Gi0/0 connected to switch and Gi0/1 connect to Primary Internet link. The modem in question is secondary connection.
Pawan Raut
Level 4
Level 4
Make sure the router port connected to switch is trunk and allowed that vlan 110
Yes. Router is connected  on Gi0/1 of switch and 110 vlan is allowed on it.
SW-10#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa0/24 on 802.1q trunking 4
Gi0/1 on 802.1q trunking 2
Gi0/2 on 802.1q trunking 4
Port Vlans allowed on trunk
Fa0/24 1-4094
Gi0/1 1-4094
Gi0/2 1-4094
Port Vlans allowed and active in management domain
Fa0/24 1-2,4,52-57,110
Gi0/1 1-2,4,52-57,110
Gi0/2 1-2,4,52-57,110
Port Vlans in spanning tree forwarding state and not pruned
When you did connect the modem to router port for test then what is the configuration you do on router interface
Below is the config on router which was working. After moving modem to switch, I created a subinterface with 110 vlan, created L2 vlan 110 on switch and configured switch port connected to modem as access port for vlan 110.
interface GigabitEthernet0/1
duplex auto
speed auto
ip route vrf IWAN-PUBLIC 0.0.0.0 0.0.0.0 x.x.x.97
it gets really confusing now to figure out what you have connected to what. Post a schematic drawing of your topology so we can see which devices are connected to which devices.
A switch is a layer 2 device, you cannot use that as a substitue for a router...
Router gi0/0 - connected to switch on Gi0/1
Switch Fa0/23 - connected to Modem.
Config on router --
Description - SW1
no ip address
load-interval 30
duplex full
speed 1000
end
interface GigabitEthernet0/0.2
description Data VLAN
encapsulation dot1Q 2 native
ip address y.y.y.2 255.255.255.0
ip access-group wormkiller in
ip access-group wormkiller out
ip directed-broadcast
ip wccp 61 redirect in
ip pim dr-priority 200
ip pim sparse-dense-mode
end
description Modem
no cdp enable
end
Config on Switch ---------------------------------------------------------
description Modem
end
description RTR01
switchport trunk native vlan 2
switchport mode trunk
mls qos trust cos
I tested modem by connecting it on Router Gi0/1 with below config and I was able to ping the next hop - x.x.x.97
description Modem
duplex auto
speed auto
Hope this clears the confusion.
post the full running configs (sh run) of both the router and the switch...
Hello
Why are you making gig0/0 on the router a subinterface for vlan 110, does it need to be, Can you not just have its a normal routed port and have the two ports on the switch interconnecting the router and the modem access port vlan 1.
If the router gig0/0 needs to be in a subinterface for vlan110, then make the port on the switch connecting to the router a trunk port and the port connecting to the modem an access port in vlan 110, but dont forget in a vrf you need to ping the vrf table
ping vrf WAN-PUBLIC x.x.x.97
Kind Regards
Paul
Hi Paul, I am creating sub-interface because there is no free port on router.
And yes I am pinging using vrf.
See below .. Hope this helps in understanding the scenario -
Config on router --
Description - SW1
no ip address
load-interval 30
duplex full
speed 1000
end
end
description Modem
no cdp enable
end
description Modem
end
description RTR01
mls qos trust cos
description Modem
duplex auto
speed auto
post a schematic drawing of your topology. You cannot connect the modem to a switch and the router to the switch as well. What brand/model are the router and the switch ?
I believe the connections cannot be like this
Modem ----------- switch--------- router
as the ISP is going to give a single IP space
https://www.quora.com/Can-I-connect-the-modem-to-the-switch-then-to-the-router
But yes, network diagram would be of great help.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
Config on router --
Description - SW1
no ip address
load-interval 30
duplex full
speed 1000
end
end
description Modem
no cdp enable
end
description Modem
end
description RTR01
mls qos trust cos
I tested modem by connecting it on Router with below config and I was able to ping the next hop - x.x.x.97
description Modem
duplex auto
speed auto
