I guess you want to use HSRP on your WAN interfaces to terminate your VPN right?
Personally, I won't use HSRP. There better way to handle redundancy on a DMVPN network.
You can have 2 tunnels UP from the spoke and play with routing path prioritization. (e.g. if using ospf you can set ip ospf priority on the tunnel interface and make your primary the best patch by setting the highest priority).
Or, the one I prefer, is on the spoke configuration, you can define the 2 HUB as cluster and define 1 Tunnel UP. The tunnel to the backup router will be bring UP when primary is down.
The configuration of clustering looks like:
p nhrp nhs HUB_IP_Primary priority 1 cluster 1
ip nhrp nhs HUB_IP_Secondary priority 2 cluster 1
ip nhrp nhs cluster 1 max connections 1 --> Says that 1 tunnel UP at the time
ip nhrp nhs fallback 5 --> Timers in second.
On the LAN side, you can setup an HSRP to force traffic going to primary or you can play around with routing protocol as well.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
